Non-Mac User Question at DVinfo.net
Final Cut Suite
Old January 22nd, 2007, 01:56 PM   #1
Is Final Cut Pro (or other "standard" Mac apps) capable of capturing 4 channels of DV audio at once? I'm a PC user stuck with Adobe Premiere (which can't do it) and am thinking of converting to Mac. Not being able to get all 4 channels of audio at once in Premiere has always been a problem for me, and using other programs to do it really kills the streamline for my editing.
Thanks.
-Michael
May the best days of your past be the worst day of your future.
Michael W. Niece is offline   Reply With Quote
Old January 22nd, 2007, 04:04 PM   #2
Michael, I did a search on the forums and looks like you can. I haven't tried it personally, so perhaps someone else can hop in. I'm pretty new to FCP and not in front of my machine at the moment.
http://dvinfo.net/conf/showthread.ph...light=channels
Jeff Krepner is offline   Reply With Quote
Old January 22nd, 2007, 11:42 PM   #3
The latest version of QT and FCP supports 4 channels of audio capture.
Shane Ross is offline   Reply With Quote
Old January 23rd, 2007, 12:48 AM   #4
I may be reading you wrong, if so, ignore this.
But if you've talking about 4 track recording mode in DV capture on a low-end camcorder, be careful you're not reducing your audio sampling rate from 48Khz down to 32Khz or lower.
Non DV standard (2-channel 48Khz) sampled audio has caused more timeline screwups among guys I've helped in the past 6 years than ANY other single problem.
(OTOH, if you're doing double system or something like A/D capture from Digibeta via SDI or Fiber Channel with concurrent 4-channel audio - then never mind!)
Bill Davis is offline   Reply
