Need Help with FCP please at DVinfo.net
Final Cut Suite
Old February 12th, 2007, 06:44 AM   #1
Help I should also add that I noticed that compared to VEGAS the FCP project is not doing 16:9 properly. I believe the image is being cropped on the left and right sides. The test or control project on Vegas looks fine. It was shot on A1 HD 1080i/60
John Huling is offline   Reply With Quote
Old February 12th, 2007, 07:56 AM   #2
Are you using the correct Easy Setup? Your Easy Setup should match your camera output.
Victor Kellar is offline   Reply With Quote
Old February 12th, 2007, 08:02 AM   #3
FCP image problem or Compressor or DVD Pro?
I don't think the problem is actually in FCP. It problabaly is somewhere between going to Compressor to DVD Pro Studio. I did noy use easy setup. But I used the "Official Larry Jordon" settings from his FCP tutorial. "Current settings" is the setting I used which is supposed to be the right one because it uses the "video sequence" as a reference...right?
