Help with P2 DVCPRO HD at DVinfo.net
Final Cut Suite
Old March 22nd, 2007, 10:34 PM   #1
I captures my footege from the HVX in 720 24p
and they look awesome. but when i drag them to the timeline in my final cut pro, they turn to the red line, wich means i need to render them, that means that it is compressing them... what can i do to work with my full quality????
Thanks for your help.
Angel Mario is offline   Reply With Quote
Old March 23rd, 2007, 03:54 AM   #2
rendering doesn't always mean compressing.
Can't help you in FCP problem though...
Andzei Matsukevits is offline   Reply With Quote
Old March 23rd, 2007, 09:01 AM   #3
Angel, look at "Sequence Settings" in Final Cut and make sure that everything (frame rate, aspect ratio, compressor) matches your original footage. For example, if you shoot 720pN/24p, your FCP sequence settings would be:
Frame size: 960 x 720
Pixel aspect ratio: HD (960 x 720)
Anamorphic: OFF
Field dominance: None
Editing timebase: 24
QuickTime Video Settings: DVCPRO HD 720p60
Hope this helps,
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old March 23rd, 2007, 09:12 AM   #4
Moved from HVX to FCP / Mac.
Chris Hurd is offline   Reply
