Need help matching these frame grabs at DVinfo.net
Final Cut Suite
Old March 26th, 2007, 05:55 PM   #1
I am trying to get these two samples to look as simular as possible in terms of exposure. On sample 2, I changed iris setting on my FX1 to eliminate the over exposure at the hair and forehead. Any suggestions on how to match these in FCP5? Levels? Color?
Glenn Davidson is offline   Reply With Quote
Old March 27th, 2007, 09:29 AM   #2
Go Go Godzilla
Images: 15
Glenn,
Use the 3-way Color Corrector filter; there are built-in advanced features that will automatically match color, gamma and tempurature based on points you select in the frame. Pick up this book from the Apple Pro Training Series: "Advanced Color Correction and Effects in FCP 5", this will outline very clearly this process and literally everything else you'll need to know about color correction in FCP.
Old March 27th, 2007, 05:51 PM   #3
Thanks Robert. That helps a lot. I did not even know that FCP had a matching filter.
