TIME CODE Reseting itself during Batch Capture. PLEASE HELP! at DVinfo.net
Final Cut Suite
Old March 29th, 2007, 09:22 AM   #1
I am encountering a very annoying problem.
When I set up several MiniDV tapes for batch capture, the time code resets itself on the captured media to 00:00:00;00, regardless of the actual timecode on the tape. This only happens when I set up more than one tape for batch capture and switch them out as FCP asks for the next tape.
When I set up a batch capture for only one tape the time code remains true to the timecode on the tape. This however makes the capture process longer than it needs to be.
If you have a solution please let me know! I really need to figure this out before I continue and edit.
Thank you!
Mariano Eckerstrand is offline   Reply With Quote
Old March 30th, 2007, 07:00 AM   #2
That's really bizarre. I assume you've ditched your preferences? Do that and reboot, see how it goes.
Daniel Stevenson is offline   Reply With Quote
Old March 30th, 2007, 07:17 AM   #3
Are you using the Apple AIC codec? That same thing happened to me using AIC.
Joe
http://JoeGoldsberry.com
Joe Goldsberry is offline   Reply
