-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Audio help, please. (https://www.dvinfo.net/forum/final-cut-suite/94970-audio-help-please.html)
Ryan Brown May 24th, 2007 07:41 PM
Audio help, please.
New member here, but avid DVXuser member, and I'm posting this on both forums for (hopefully) more suggestions.
I'm almost finished editing my current wedding, and have some major audio issue's (which I saved for last).
My shooter went directly into the mixer via XLR, and his levels look just fine. Problem is, the DJ had HIS channel up WAY too high, and all of the audio from the ceremony into my shooters DVX sounds really blown out. Don't know what the hell my shooter was thinking... he had headphone's and should've caught this...
I usually use PEAK for audio issue's, but I'm open to suggestions on this one (I've got ST pro, logic, etc)
What are my best options to get this to sound at least half-way decent??
Kind of in a pinch on this one, so, like I said, I'm open to ANY and ALL advice/suggestions.
thanks guys/gals
-brown
Johan Forssblad May 31st, 2007 11:33 AM
Hi Ryan,
Not funny to hear. It is like blowing the exposure. You can make it more grey (weaker). But you cannot get details back in the blown out parts without faking them.
But the clipping creates a lot of higher frequency noise like 3xf0, 5xf0 etc.
That means an A tone (440 Hz) will sound like 440 + 1320 + 2200 ... Hz when it gets distorted by clipping.
If you don't have a lot of different sound with different frequencies you can try to use an EQ filter to supress the frequencies above the normal spectrum.
Perhaps it can help a bit. I used this technique on a soundtrack from a big band where the drummer suddenly got excited and punched harder than before. I applied the filter softly only where needed. But here it was a matter about only 1-3 dB too much. It fixed it quite well on his solo part.
Good luck! /Johan
