-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Capturing Clips in FCP (https://www.dvinfo.net/forum/final-cut-suite/95467-capturing-clips-fcp.html)
Dick Campbell June 1st, 2007 09:46 PM
Sorry Kelly, you read me the wrong way. You asked why the software was designed as such. iMovie was designed to be easy to use and to make decisions for the editor to keep it simple. I just answered the question, it was not intended to be personal.
Kelly Harmsworth June 2nd, 2007 02:29 PM
No problem man. I gotcha.
Cheers
Kelly
Yeo Wee Han June 4th, 2007 07:24 AM
Rickey has got the method spot-on but that will not work on HDV...only regular DV clips.
The whole clip is split into shorter clips and the in and out points will be when you started and stopped recording. The entire original clip will consist of markers after it finishes scanning and under the Browser, the subclips are automatically created under the clipname itself.
Hope its not confusing!
Cheers
WeeHan
Rickey Brillantes June 4th, 2007 02:38 PM
WeeHan
HDV does that too more easier imo. In log and capture clip setting check create new clip on start stop and it will give you the sub clips.
You have to do this before you capture your media.
Cheers!
Rickey
