FCP6 - realtime output to HDMI & S-Video at DVinfo.net
Final Cut Suite
Old June 28th, 2007, 01:30 AM   #1
Hello,
We will be setting up a new editing computer whic will be used to edit mostly in HDV. A lot of our projects are edited and mastered in HDV, but usually (for now) we downconvert them to SD for DVD usage. So we are looking for the best/value hardware solution. We will be viewing the HD footage on a Sony 40" LCD with HDMI input, and a Sony CRT monitor with S-Video input. We would like them both to show realtime from an HDV timeline.
The only possible solution I can come up with at this point is a Blackmagic DeckLink HD Extreme ($995) outputting to S-Video to monitor and SDI to a Blackmagic HDLink converter ($445) to HDMI monitor.
Is this the only solution? Has anyone tried a similar approach? Will this setup keep sync? I think AJA's new IoHD would work for my needs but I can't justify $3,500 so I can edit in HDV. I will not be using Pro Rez....
Any thoughts/suggestions would be appreciated.
Carl Crum is offline   Reply With Quote
Old June 28th, 2007, 09:02 AM   #2
Sponsor: Electronic Mailbox
check out the Black magic Intensity Pro. You get HDMI & analog I/O forunder $350! http://www.videoguys.com/intensitypro.html
Gary
Check out http://www.videoguys.com 800 323-2325 We are the video editing and live video production experts! DV InfoNet members save 5%! Use Coupon Code DVINFO5OFF
Gary Bettan is offline   Reply With Quote
Old June 28th, 2007, 03:38 PM   #3
Intensity Pro is not simultaneous output
Thanks for the suggestion, but the Intensity Pro cannot output to HDMI and s-Video at the same time. You must select one or the other.
Old June 28th, 2007, 04:04 PM   #4
too bad - I wasn't sure about that. has anyone tried running 2 intensity Pro cards at the same time, on set to HDNI, the other to analog???
