Installation flaw on FCS2 from FCS1? Frame Rate Converter conflict at DVinfo.net
Final Cut Suite
Old July 5th, 2007, 09:03 AM   #1
I ran into problem that I could not make the DVCPRO HD Frame Rate Converter function in the Tools menu, make the long story short, it seems that FCS2 installation forgets to erase the old "plugin" from the plugins folder, and maybe because the program is integrated in the application, the old plugin's presence seems to conflict.
I removed the plugin then the function started working.
Kaku Ito is offline   Reply With Quote
Old July 5th, 2007, 04:52 PM   #2
Where is that plug-in in the hard drive? I searched and couldn't find it.
Elmer Lang is offline   Reply With Quote
Old July 5th, 2007, 09:49 PM   #3
The new FCP6 does not have it, it is probably included in the application resource, then the old plugin was present (not erased from the upgrade installation) then it conflicts. So, if you don't see it, it's not a problem.
Old July 5th, 2007, 09:59 PM   #4
How could I see it if I don't know where to look for it.
No problem.
Old July 6th, 2007, 07:45 AM   #5
Kaku, I take it this was the source of your FRC issues?
Gene Crucean is offline   Reply With Quote
Old July 6th, 2007, 08:41 AM   #6
Gene, yep,
Elmer, I thought you did the spotlight search and couldn't find it, sorry.
Here's the details.
file name: DVCPROHD Frame Rate Convertor.bundle
location: library/Application Support/Final Cut Pro system Support/Plugins
