does HDV needs rendering on HDV-timeline? at DVinfo.net
Final Cut Suite
Old July 14th, 2007, 09:02 PM   #1
Working with a Canon Xh A1 in HDV modus (1080i50)
Using FCP, created a HDV timeline. When dropping my images on my timeline, they need rendering... Is this normal?
I think not, but I'm not quite sure.....
Eugene Presley is offline   Reply With Quote
Old July 14th, 2007, 11:58 PM   #2
Did you set an easy setup for your footage? Once you change your easy setup, the sequences you have created previously will not change. Create a new sequence and you should be fine. Also, you can scroll over in the bin to check the sequence settings vs the footage settings: frame rate, compression type, frame size, etc.
David Chapman
www.davechapfilms.com
David Chapman is offline   Reply With Quote
Old July 15th, 2007, 05:37 AM   #3
Thanks a lot James!!!
