Motion issue with Flash encoding at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old January 25th, 2009, 03:00 PM   #1
I have been encoding a few videos from an HDV source into Flash (.flv) using Premiere Pro 2.0's Adobe Media Encoder. The quality is fine, but when I play back using Adobe's Flash Player, I notice there are problems with motion. The best way I can describe it is, in scenes of moderate to heavy motion, a horizontal line will appear where it's almost as if what is above the line is out of sync with what is below the line. The line will only appear for a frame or so, and then disappear. However, this goes on for however long there is a degree of motion, appearing in various parts of the frame. I've tried to take a screenshot of the problem, but either cannot get it or the problem occurs only during playback.
Any suggestions on how to fix this?
Section 1 Films
Joshua Clarke is offline   Reply With Quote
Old January 25th, 2009, 10:37 PM   #2
Do you still get the same effect if you play it back on another computer?
Old January 25th, 2009, 11:41 PM   #3
Motion Horizontal Breaking with Flash Video
From you're description this is a pretty common issue with all Flash and can be seen all over the web.
Horizontal panning (especially of a complex scene) will typically give this "break" where one half or one third (or whatever) of the picture seems to lag behind the remainder for a fraction of a second. This effect is (unfortunately) totally normal for Flash and is the price we pay for accessible web video encoded with relatively small amounts of data.
Joshua, I went through a similar "is it something I've done wrong" problem solving procedure when I first started doing web video (especially after Stage6 folded as they used the DivX rather than Flash encoding and that does not seem to exhibit this fault).
But Flash is universal and DivX is not and that's just the way it is. If you want the world to view your videos then Flash is the way to go, faults and all.
Also, for videos I "shoot for web" I tend to adjust my shooting style to avoid too much (or too fast) horizontal panning as this triggers the fault described. It's all about knowing the limitations and working as best you can within them to get a great product!
Old January 26th, 2009, 03:16 PM   #4
Andy, great information. Thank you very much.
Unfortunately, when we shot this we knew what the final delivery was, but we didn't know in what format. I was figuring .wmv, with which I've never had a problem. The web designer that was hired is the one who pushed for Flash, so that's what we had to go with. Thanks again for the info and I'll keep what you said in mind.
Graham, yes, unfortunately it shows up on two systems.
Section 1 Films
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
