Flash video progressive download at DVinfo.net
Go Back   DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
Old September 11th, 2004, 07:56 AM   #1
I have a 2 min. video encoded in flash (flkv/swf) format with Sorenson Squeeze 4 and the Spark Pro codec.
It looks very good but doesn't play in the browser before the clip is completely downloaded.. even if it is supposed to act just like Quicktime progressive download video files.
Anyone who knows what could be reason for that?
x
Bjørn Sørensen is offline   Reply With Quote
Old September 30th, 2004, 05:30 PM   #2
It sounds like you have 'embedded' the flv file into your swf file. If this is the case, it will as you've stated download the whole file before playing.
(assuming your using Flash MX Pro 2004)
you should drag the MediaPlayback component from the components panel to the stage, and set it to the size you require...
then in the 'components inspector' panel type the relative URL to your FLV movie, and set the other parameters...
I've had wicked results with this and even the default MediaPlayback component looks groovy!
Note your users will have to have the flashplayer 7 plugin (I think... or at least 6) to view a progressive flv.
There is loads of stuff on the macromedia site about flash video, check out the technotes www.macromedia.com
Deborah Gregory is offline   Reply With Quote
Old October 1st, 2004, 10:11 AM   #3
Hi Bjørn
Streaming Movie with Flash.
There are two ways of doing it.
First you embed the file into flash directly The problem is that the in order to watch the movie you have to download the hole thing. This will take a lot of time and after a minute sound and video get out of sync.
The best way is to link the movie to a flash event.
You upload the file directly to you web server. No messing with the flash file itself. I use .mov format on the net.
If the user uses the Microsoft player, It will start to play the movie on the spot , buffering the rest.
I use this all the time and it works great. The Best thing is the fact Video and sound is never out of sync.
Hope this is some help
Stephan
Stephan Mayer is offline   Reply With Quote
Old October 2nd, 2004, 02:05 AM   #4
Hi Stephan.
I started this thread about two weeks ago. In the meantime I have found the answer myself.. I now use Sorenson Squeeze 4 to encode my movies to flv.format which I then play with a Media Component. It works perfect and is very easy to set up. Squeeze is doing a good job.
The big advantage with flash is that it plays instantly on both mac and pc (with Flash Player 7). Why use .mov format ??
x
Old December 27th, 2004, 04:37 PM   #5
Sorenson Squeeze 4
Hello Bjorn,
Does Squeeze 4 have the option of setting different frame rates? I am looking specifically for 60 frames per second.
Thanks in advance.
Alan Van Vliet
Alan Van Vliet is offline   Reply With Quote
Old December 27th, 2004, 04:39 PM   #6
Squeeze 4
Bjorn,
Sorry, that should have read 60 frames per minute.
Al
Old January 9th, 2005, 09:38 AM   #7
Sorry again, I was right the first time. Doesn't happen very often.
60 frames per second is what I am looking for.
Regards, AL
Old January 19th, 2005, 04:32 PM   #8
Hello,
Just got Flash MX Pro. I have QT clips at my site and would like to add Flash clips.
Has anyone imported uncompressed FCP movies, used the Sorenson Spark codec in Flash Pro to compress and outputted .flv or .swf clips? The Flash ‘How do I’ has got me a bit discombobulated. Clips will be 2-7 minutes.
Any opinions, hints or tips would be highly appreciated.
All the best,
elmer lang
http://elmerlang.com
QT clips at: http://elmerlang.com/H2EclipsM.html
Elmer Lang is offline   Reply
  You are here: DV Info Net > Cross-Platform Post Production Solutions > Distribution Center > Flash / Web Video
