Are you certified to fly commercially? at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Flying Cameras
Flying Cameras
UAV, Helicam, and all other aerial videography topics.
Old June 8th, 2015, 08:05 PM   #1
I am not, but here is Hawaii's first company that received their section 333 exemption from the FAA. Congrats!! Who on this forum is approved to fly commercially?
Joint venture becomes first in Hawaii to receive FAA commercial drone certification | More Local News - KITV Home
Old June 8th, 2015, 09:14 PM   #2
Re: Are you certified to fly commercially?
Aren't there only 7 or 8 companies with approval?
The extra trick is, you have to file for permission with each individual project, which is absurd.
I can't wait until the new rules make this possible for more of us.
Old June 8th, 2015, 11:37 PM   #3
7 companies were the first original batch to be approved, I believe the count as of today is in the hundreds. I also believe the requirement that you must be a private pilot has been relaxed; a sport pilot cert is the minimum prerequisite now. Every project's flight plan also needs to be registered and approved by the FAA at least 72 hours ahead of time.
Old June 9th, 2015, 04:32 AM   #4
Just saw this NOTAM filed a couple of days ago here in ATL:
ATL 06/038 ATL AIRSPACE UNMANNED AIRCRAFT WITHIN AN AREA DEFINED AS 1NM
RADIUS OF ATL256022 SFC-400FT ABOVE GROUND LEVEL THURSDAY 1300-2100
1506041300-1506252100
Old June 10th, 2015, 09:49 AM   #5
Images: 1
Lots of companies 'approved' now and awhile back, the FAA streamlined things a bit by allowing a blanket COA for ops at 200 feet AGL and below. No need to file a separate request for each op below that altitude.
-gb-
Old June 10th, 2015, 11:05 AM   #6
I see that in the past 3 months since I last checked the number of approved companies jumped from 7 or 8 to over 500.
Old June 13th, 2015, 02:25 PM   #7
We are. It's sort of a mixed blessing at this stage of the game. It's very difficult to fly in a feature film without it. Also difficult to get hull insurance with no 333 too. On the other side of the coin, many smaller productions don't want to deal with all the restrictions and opt to go with an unauthorized crew instead. Crazy times.
Wendell
www.perfectperspectivesaerial.com
Wendell Adkins is offline   Reply With Quote
Old June 16th, 2015, 04:01 AM   #8
We are - but in the UK.
As said above, it's a bit of a mixed blessing since a lot of people are doing it illegally and getting some great (illegal) shots that we have to turn down.
Of course I'd rather be legal than not ;)
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old June 19th, 2015, 08:01 AM   #9
Images: 1
The problem, as Wendell alluded to, is that once you have the waiver and COA, the restrictions placed upon your small UAS are the same as those that apply to manned aircraft, resulting in needless separation distances from people and structures. 500' is a great rule for a manned aircraft, but not so great when you want to fly in front of a residence for aerial real estate work using a 2 to 5 lb. aerial platform.
-gb-.
Old June 19th, 2015, 10:23 AM   #10
My understanding is that it's a maximum of 500 ft above ground level or that least that's what proposed in the Small UAS NPRM.
Although, flying below 200ft seems to be the COA restriction .https://www.faa.gov/news/updates/?newsId=82245
Not below 500 ft would get drones flying with manned aircraft.
Old June 21st, 2015, 07:19 AM   #11
Images: 1
Yes, the NPRM proposes a 500 AGL max altitude restriction.However, the NPRM isn't a current regulation so it does not apply as of yet.
Recently, the FAA relaxed the requirement to get a separate COA for EACH operation if you are going to operate at or below 200 AGL. It's basically a blanket COA for the first 200 feet up.
But they are still applying the normal separation distance of 500 ft. that has been applicable to manned aircraft.
§91.119 Minimum safe altitudes: General.
Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes:
(a) Anywhere. An altitude allowing, if a power unit fails, an emergency landing without undue hazard to persons or property on the surface.
(b) Over congested areas. Over any congested area of a city, town, or settlement, or over any open air assembly of persons, an altitude of 1,000 feet above the highest obstacle within a horizontal radius of 2,000 feet of the aircraft.
(c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure.
(d) Helicopters, powered parachutes, and weight-shift-control aircraft. If the operation is conducted without hazard to persons or property on the surface—
(1) A helicopter may be operated at less than the minimums prescribed in paragraph (b) or (c) of this section, provided each person operating the helicopter complies with any routes or altitudes specifically prescribed for helicopters by the FAA; and
(2) A powered parachute or weight-shift-control aircraft may be operated at less than the minimums prescribed in paragraph (c) of this section.
The notion of whether you currently even need an exemption to fly commercially is the subject of legal debate. As such, there are many sUAS commercial operations being conducted without an exemption and the FAA stance at this point is that they will only pursue operators who engage in wreckless or careless operations. Ironically, it's the commercial operators who are the least likely to be engaging in such behavior because they have a lot more discipline in the way they operate.
It's a mess, and they are way behind the curve as opposed to other countries.
-gb-
Greg Boston is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Flying Cameras
