phantom 3 profesiona and ipad mini 2 and the annoying video lag at DVinfo.net
Go Back   DV Info Net > Most Recent Additions... > Flying Cameras
Flying Cameras
UAV, Helicam, and all other aerial videography topics.
Old August 14th, 2015, 10:17 PM   #1
hello there
i have bought a phantom 3 pro yesterday and the ipad mini 2 same day
i have the hardware decode enable
i have disable the video cashe
and i have the ipad mini 2 on airplane mode
but still i have this annoying video lag which is makes this tool useless for me cause like this is dangerous and not safe to do serious work.
do you know if there is anything else i can do?
thanks in advance
Anthony Mozora is offline   Reply With Quote
Old August 14th, 2015, 11:22 PM   #2
Re: phantom 3 profesiona and ipad mini 2 and the annoying video lag
How much lag do you have?
Mike Watson is offline   Reply With Quote
Old August 14th, 2015, 11:30 PM   #3
Re: phantom 3 profesional and ipad mini 2 and the annoying video lag
very little. about 0.5secs/ 1sec
which is frustrating cause i had a phantom 2 h33d with FPV and that was beyond perfect.
with any lag i can capture video from distance but i can not get close to buildings or be creative in anyway as is not safe.
Old August 15th, 2015, 09:53 AM   #4
Have you tried lowering the video transmission bit rate in the image transmission settings? Bring it down to the lowest setting and see if that helps.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old August 15th, 2015, 09:58 AM   #5
I'm also getting 0.5 to 1 sec with the same rig. I was getting some lag before with the 2V+ and it hadn't occurred to me to be annoyed by the 3, but you're right, there's more lag now.
Old August 15th, 2015, 10:47 AM   #6
i tried to do this but i can not find a proper channel that works faster .... actually i found more delay...
Old August 15th, 2015, 10:51 AM   #7
dont know what to do..
I also have the phantom 2 H33D with a gopro 3black + and the FPV is an amazing experience with this rig
no lags .... smooth ...no issues at all ......
I went with the phantom 3 pro having the best possible hopes for even better results and instead of that i wish i was really getting a gopro 4 and a gimbal H4-3D .....this could have been the best combo for me
but i wasted money on an ipad mini 2 that it seems that can not give me better results!
somebody told me earlier today that the only ipad that actually works is the IPAD AIR 2....
i could give 5* to the phantom 3 but now am giving it 1* cause of the failure to a perfect video signal
Old August 15th, 2015, 11:00 AM   #8
It's because the newer craft have HD feeds versus the older SD video feeds. Your gopro is an analog feed versus the digital Light-bridge signal.
Old August 15th, 2015, 11:12 AM   #9
Not really a channel thing, it's a bandwidth thing. Maybe it's missing from the latest app? You used to be able to adjust quality from like 2Mbps to 8Mbps or something like that. For longer range and less lag.
Old August 16th, 2015, 12:30 AM   #10
From what I've read online, the video lag is normal. Lightbridge isn't mean for FPV flying, it's meant for framing up the shot. Because it's over wifi, video lag is inevitable - not like an analog video feed which is almost instant but the quality is much worse.
Viewing a GoPro feed over wifi is the same - 1-2 seconds lag.
Jody Arnott is offline   Reply With Quote
Old August 16th, 2015, 10:20 AM   #11
Images: 1
This is true. However, I have also read that newer iPads seem to handle the higher quality video feed with less lag. But it's definitely not meant to be an FPV set up.
-gb-
Old August 21st, 2015, 03:50 PM   #12
The lag is most likely related to the iPad getting warm and thermal throttling in its processor kicking in (thus making it less able to process and display the video feed).
I get far worse lagging when the ambient temp is high than I do when it's cooler out.
Justin Bregar is offline   Reply
  You are here: DV Info Net > Most Recent Additions... > Flying Cameras
