FS-H200 Portable Compact Flash DTE Recorder at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old June 2nd, 2009, 01:11 PM   #1
Sponsor: Electronic Mailbox
The all new FS-H200 Portable Compact Flash DTE Recorder brings ultra-reliable solid state acquisition with Direct To Edit Technology to your DV or HDV camcorder. FS-H200 utilizes standard Type 1 removable Compact Flash media which provides fast, reliable, and low-cost recording.
Focus Enhancements
ProVideo Coalition.com: Bruce's Blog by Bruce A. Johnson | Founder
Gary
Check out http://www.videoguys.com 800 323-2325 We are the video editing and live video production experts! DV InfoNet members save 5%! Use Coupon Code DVINFO5OFF
Gary Bettan is offline   Reply With Quote
Old June 6th, 2009, 04:34 PM   #2
Convergent Design
Hi Gary-
Interesting product. Great to see the use of Compact Flash cards. I wonder why they need 266X cards for HDV data-rates? HDV = 25Mbps, the nanoFlash can use a much lower cost 133X card (Kingston 32GB) for data-rates up to 140Mbps.
Cheers-
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old June 16th, 2009, 10:21 AM   #3
Gary,
The camera compatibility list on your website does not include the JVC GY-HD110.
Will it work with this camera?
www.Personal-Documentary.com
John McQuiston is offline   Reply With Quote
Old June 21st, 2009, 10:14 AM   #4
My FS-4 HD 40 GB is not on the list for my JVC GY-HD110 but it still works.
Mark Boyer is offline   Reply With Quote
Old August 6th, 2009, 07:06 PM   #5
Has anyone tried one of these drives with the gyhd 100,101 or 110 series yet.
regards
Ian Skurrie
Ian Skurrie is offline   Reply With Quote
Old December 15th, 2009, 01:59 PM   #6
Will this work with the Sony PDW F355?? I didn't see that on the list either.
thanks,
-jeremy
Jeremy Borton is offline   Reply With Quote
Old December 15th, 2009, 08:41 PM   #7
Following Focus Enhancements for quite some time, the FS-H200 Pro is really the FS-H200 with the ability to play back clips (via proxy mpeg 4) and embed metadata across a wired or bluetooth connection. Essentially it's the same upgrade in a solid state drive as the Version 2.0 firmware upgrade of the hard drive based FS-5.
While I like the idea of a solid state memory FS-H200 Pro, I'm still getting the hard drive based FS-5 for two reasons:
1. The FS-5 is $400 cheaper (considering the additional price of flash cards)
2. The FS-5 has more memory (100 GB vs. 64 GB max with the H200)
I'm not overly concerned about the vulnerability of a hard drive over a solid state drive. I've used three DR-HD100 DTEs for over three years with no problems. Where I see a problem, and it's an inherent problem across all recorders, is the lousy 6-pin Firewire connector and the even lousier 4-pin connectors. They tend to get loose over time and are too easy to disconnect.
I plan on posting a comprehensive review on the FS-5. Since I know folks at Focus, I may try to get an eval copy of the FS-H200 Pro as well. I'll post a link here when done. By the way, if you're interested in reading a post I wrote on the DR-HD100 (essentially the FS-4 HD for the JVC GY-HDXXX ProHD series of cameras), check this:
Focus Enhancements DTE DR-HD100 - Still the Best Capture Medium - JVC DR-HD100GB60 HD 60GB Portable DTE Recorder for ProHD Camcorders - Epinions.com
Dave Burckhard is offline   Reply With Quote
Old March 29th, 2016, 07:41 PM   #8
Re: FS-H200 Portable Compact Flash DTE Recorder
So I know this thread is a couple years old but I just purchased a Canon XH-A1s and a FS-H200 DTE. BUT I am having trouble getting them to talk to each other in HDV. Was there any setting other then the DV selection switched ON under system set-up in the camera?? Or is there a setting I am missing in the DTE ( I have reset both to factory settings, or so I believe), tried it in Quick Time and M2T with 24f, 30f, and 60i.
The cam and DTE will talk fine in DV mode and records really good, but when I switch both to HDV it doesn't record. The cam notices it is plugged in when I connect the firewire but that is all.
Thanks for any help , Andy
PS I am cross posting this to a couple of the threads on the fs-h200 if you see this post elsewhere given the age of the thread and the necessity to solve this problem before an event in April.
Andy Johnson is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
