External battery pack for FS-CV (or FS-4?) at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old December 24th, 2009, 01:20 PM   #1
Has anybody found a good external battery pack solution for the FS-CV (or for the FS-4 for that matter?)
The problem with the FS-CV specifically is: (a) there is no extended capacity battery pack available for it, (b) there is no separate battery charger available for it--you have to load them into the FS-CV to charge them. :( The standard capacity battery is rated for 180 minutes/3 hours so, for a six hours shoot -- to be safe -- you'd need three batteries for each FS-CV
The only (not very good) option seems to be to buy several standard capacity batteries and try and recharge them overnight. I have three FS-CVs (for three XLH1s), so that means "recharge hell" for nine batteries given that I'm shooting for five our six hours a day in the field and then need to "empty" the FS-CVs at the end of the day.
Has anyone found a suitable belt pack that will allow me to drive an FS-CV for seven hours? (Which is roughly the HDV capacity of the FC-CV.) I have a feeling that I'll need to make one up by doing a cable-ectomy on existing battery pack, eg. Bescor.
It needs 11-18 VDC, 7.5 watts. (That is, at, say 12v, 0.625 amps.) So I'd need about a 50 watt hour pack. (Visions of dragging a sealed lead acid battery around on a little cart behind me.... Lithium Ion would be much lighter!)
While I think of it, has anyone found a good belt pack for the FS-CV/4 too? Don't really want it on the camera because of the increased carry weight!
Thanks in advance
Andy
Forensic Software/Image Analyst & Educational DVD Production
Portland, Oregon ("Orygun"), USA : www.jli.com
Andy Johnson-Laird is offline   Reply With Quote
Old February 8th, 2010, 11:41 AM   #2
Tekkeon MP3450
Newegg.com - Tekkeon myPower ALL External Laptop Battery MP3450 - AUX Battery Packs
Canon 7D and 5D Mark II,Canon XL H1, XL2, Cinevate Atlas 30, Advanta Jib, AJA i/O, KONA LHe, AJA I/O HD, ZEISS PRIMES, G5 Quad Core, MacPro 2.66GHz, XSERVE RAID 10TB
Gregory Dillard is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
