Using FS-5 to record non-camcorder source at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old March 10th, 2010, 11:46 AM   #1
Hi good video folk, this is my first post.
I recently had the need to record a composite signal from a switched 3 camera setup. I had hoped to somehow record into the FS-5 and made a technical plan to put composite into my Sony miniDV camcorder and have the FS-5 record the signal.
Oops - that didn't work! When the firewire FS-5 was connected to the Sony, the Sony would not take the video input.
I ended up using a lousy USB capture device to record direct to a laptop, but it was rife with quality problems.
Has anyone attempted anything like this with success?
thanks!
-james
James Lloyd is offline   Reply With Quote
Old March 11th, 2010, 03:46 PM   #2
James,
In our edit lab, we use the following...
1. Data Video - Video Converter
With this device, we can plug any composite source from VCR, DVD or camera and record directly to the FS-5 through the firewire port on the Converter Box. We keep an FS-5 unit attached to the Converter Box for easy transfer.
2. Sony GV-D1000 MiniDV player/recorder
With this device, we play our MiniDV tape and record to the FS-5 through the firewire port.
However, we cannont connect a composite source to this device and also record. The composite source would have to be first recorded to MiniDV tape, then the tape played while the FS-5 records.
Perhaps this is the same with the Sony MiniDV camera you are using. It may not allow a composite signal to go out through the firewire port. If so, you can always record to MiniDV tape (always a good backup) and then record to the FS-5.
Hope this helps.
Jonas Hamilton is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
