Problems with overheating - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old September 11th, 2005, 01:44 PM   #16
Contributor
Thanks for the long winded reply.
Now I understand what you are going through. I hope everything turns out ok for you.
I think you and Dan know better about the bit rate. What you are saying makes sense, otherwise a 60 min. tape would sometimes be a 65 min. tape or a 50 min. tape. Then, I wonder what the business is about the different cbr in your test. There is a big difference. Does the footage from the NTSC unit look significantly worse than other footage. Maybe, if you feel like it, you could shoot the same subject matter you shot with the NTSC FS-4, onto tape and compare how they look.
Cheers
Daniel Kohl
Frankenstein meets XL1
Daniel Kohl is offline   Reply With Quote
Old September 12th, 2005, 01:32 AM   #17
Daniel,
When I receive the unit I will do more acurate tests.
David
David Morton is offline   Reply With Quote
Old September 20th, 2005, 06:16 AM   #18
Contributor
FWIW Focus definitely make an NTSC and a PAL unit. I believe they do this to try and restrict cross border trading, and/or to charge more for PAL units. For example on B&H's website there is $US400 differential between identical PAL and NTSC units. I don't believe it's hardware related as a simple firmware update will allow existing units to take all HDV rates, therefore timecode could not be the issue as all the existing HDV cameras shoot at both 25/30 or 50/60Hz. .
I wrote to Focus to request they change this policy, but I'm not holding my breath.
John Mitchell is offline   Reply With Quote
Old September 22nd, 2005, 06:10 AM   #19
Focus returned the SAME unit to me and refunded the postage costs. It is now a PAL unit so they CAN be converted. I bet the cost of coversion would be less than the $400 difference in price.
David
Old September 22nd, 2005, 01:36 PM   #20
Contributor
Thanks for the update David.
I can't say that this realization makes me feel very good about Focuses general policies in this matter.
Daniel Kohl
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
