FS-1 and FS-4 problems at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old July 23rd, 2006, 10:49 PM   #1
I recently shot a wedding using 2 Canon XL1s - one with aFireStore FS-1 and the other with and FS-4.
I have used the FS-4 many times without any problems but a few times on this shoot it would be in record mode and the counter would not move - A couple of times it restarted on me in the middle of recording. Once I had to pull the power to the unit just to get it to turn off because it locked up and would not turn off with the "off" button.
This is the first time I used the FS-1. Alot of artifacting! Also about 30% of the files it saved have a file size of 0kb. And I get errors that say something about the wrong codec being used or something like that.
Anyone know what is going on with these FireStores of mine?
Jeff
Jeff Bettendorf is offline   Reply With Quote
Old July 24th, 2006, 12:11 PM   #2
Focus Enhancements
Jeff,
These issues do not seem normal. Have you contacted Focus tech support? If not, you can reach them at 763-398-1658 or at support@focusinfo.com.
Matt
Matt McEwen is offline   Reply With Quote
Old July 24th, 2006, 12:18 PM   #3
I have not been able to get ahold of tech support yet. To be more clear... the errors about the codec are when I try to open the files in windows media player. If I try to open the files in Premiere Pro the program shuts down with no errors.
Is there a way to repair those files? What does "repair file" and "repair disk" do on the FireStore?
Jeff
Old July 24th, 2006, 01:00 PM   #4
Focus Enhancements
Sounds like your FS-1 is set to AVI Type 1, which is not compatible with Premiere (and in some cases Windows Media Player). Try using the AVI Type 2 setting. If you need to convert files, we do off the DV File Converter app that allows conversion between file formats. See more information at: http://www.focusinfo.com/solutions/catalog.asp?id=8
Hope that helps,
Matt McEwen
Old July 24th, 2006, 01:39 PM   #5
Everything was recorded in AVI2... I just double checked.
Any other suggestions? I thought I read about the problem with the 0kb file size but now cannot find it.
Thanks again,
Jeff
Old July 24th, 2006, 02:34 PM   #6
Focus Enhancements
Hi Jeff,
I will have someone from tech support contact you. The symptoms you are reporting sound identical to what occurs with an AVI Type 1 recording, so I think the best bet is for tech support to contact you. What phone number can they reach you at?...I will have someone call you.
Matt
Old July 24th, 2006, 05:43 PM   #7
I emailed you with my phone number.
Jeff
Old July 25th, 2006, 11:53 AM   #8
Focus Enhancements
Our tech support staff will be calling you shortly.
Matt
Old July 26th, 2006, 10:31 AM   #9
"I have used the FS-4 many times without any problems but a few times on this shoot it would be in record mode and the counter would not move - A couple of times it restarted on me in the middle of recording. Once I had to pull the power to the unit just to get it to turn off because it locked up and would not turn off with the "off" button."
Hi Jeff.
I use the same setup: XL1-s + FS4, and encontered on occasion the same problem. I found out that it was due to a poor connection between the firewire cable and the XL1-s. Make shure that the firewire plug is firmly attached to the camera, if it dangles the FS4 loses connection and starts the erractic beaviour. This could be your problem.
Hope it helps,
Arnaldo
Arnaldo Paixao is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
