Firestore Battery at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old January 18th, 2007, 09:02 PM   #1
Firestore Battery
Bought a FE Firestore FS-C. Getting ready to do a documentary with a lot of shooting in the field.
Any advice for battery power other than the 90 minutes battery that came with it? I can't find the 180 minute life battery anywhere (all sold out!). Any other power options?
Ryan Flesher
Xh-A1, FS-C, Fig Rig
Ryan Flesher is offline   Reply With Quote
Old January 18th, 2007, 10:14 PM   #2
Give this a try
http://www.dvinfo.net/conf/showthread.php?t=80042
Not sure if it fits, but it's worth a call.
David Yuen is offline   Reply With Quote
Old January 19th, 2007, 07:37 AM   #3
Images: 10
I'm usinf an IDX NP7 battery system. It has an output that will directly feed the FS4 series of HD recorders. Works great!
Old January 20th, 2007, 11:23 PM   #4
Power for Firestore
I use a 13.2 volt battery belt (that I originally bought from Armato's for powering a video light) to power my Firestore. All you need is a cigarette lighter adapter cable to connect the Firestore to the belt (I actually found the one I needed at a local "Dollar or Less" type of store). My belt will easily power the Firestore for its full 80 GB (6 hour) capacity but if you power anything else with the same belt at the same time (like a light or an LCD monitor) then it obviously won't work as long.
Gary Burlingame is offline   Reply With Quote
Old January 20th, 2007, 11:31 PM   #5
I use a battery belt myself
I also use a battery belt, which comes with my NRG Varalux light and it powers both the FS-4 (40GB) and light just fine on just 12 volts. I'm glad I have two belts, so I can charge one while using the other.
I got my cigarette adapter and Adaptaplug "L" connector from Radio Shack for $9.
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
