Cineform ConnectHD and VirtualDub at DVinfo.net
Topics about HD production.
Old April 4th, 2005, 09:04 PM   #1
Interestingly, there's a distinct quality difference for any ConnectHD output from Vegas versus identical output from VirtualDub using ConnectHD (no modification, no filter).
Here's a comparison:
http://www.mooreusa.net/normal.jpg
http://www.mooreusa.net/vdub.jpg
Look at the walls in particular.
Also the file size of the vdub clip is smaller. Clearly it is not using the highest quality setting for ConnectHD. Uncompressed looks fine.
Is there any way to change the quality setting vdub uses? Vegas is using higher quality - why isn't vdub? Thanks!
Peter Moore is offline   Reply With Quote
Old April 4th, 2005, 09:08 PM   #2
Again, Vdub doesn't have the ability to handle the 601 colorspace. This is why we've examined other methods of frameserving, and why we offer the preset for the Color Matrix in Vegas.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 4th, 2005, 09:15 PM   #3
But you see the comparison - colors are identical, but there is splotchiness with the vdub output. Is that due to the colorspace? I am not using the preset in Vegas and am still getting better results than Vdub.
Old April 4th, 2005, 09:33 PM   #4
The other problem is vdub gives me a much sharper deinterlace than Vegas' blend fields does. Any other way to deinterlace besides using blend fields?
