50P 720HDV workflow at DVinfo.net
Topics about HD production.
Old March 9th, 2010, 04:23 PM   #1
50P 720HDV workflow
Hey,
Does anyone know a good workflow to capture 50 720P footage, I use HDVSPLITTER for the capture once I put it into premiere cs4 and render it out to convert uncompressed SD 720x576 i get audio issues not being synced, The premiere project is set to 25fps, is this the issue does premiere convert the m2t footage accordingly or do i have to convert it to 25fps before i import to premiere? And if so whats the best program, im sick and tired of the sound out of sync
Ken Grebenare is offline   Reply With Quote
Old March 11th, 2010, 04:25 PM   #2
Lol
Does no1 know how to fix this?
Old March 20th, 2010, 10:06 PM   #3
does the hdvsplitter capture correctly with sound in sync?
If your source is at 50fps, then change the project settings to match your source footage. If everything syncs perfectly in your timeline, then you should be good to go.
However, if you're having issues with sync after you export, then i would recheck your export settings. If the export settings are fine, then check your computer hardware - is the hard disk being used efficiently? Can't give a proper answer without going through all this, I'm afraid.
Let me know how it pans out.
Sareesh Sudhakaran is offline   Reply
