*.ts What is it? at DVinfo.net
Topics about HD production.
Old January 30th, 2007, 06:30 AM   #1
*.ts What is it?
Recently found file with extension *.ts. Logically thinking I understood these two letters as Transport Stream. But players and Premiere Pro don't recognize these file properly. I could watch this file only after processing in ProCoder. Does anyone know about such files and how to use them properly?
Alexey Mordovin is offline   Reply With Quote
Old January 30th, 2007, 07:02 AM   #2
They are MPEG2 files. Some applications will recognize them if you change the extension from .ts to .mpg or .mpeg, others won't.
Use MPEG Streamclip (freeware) to convert to QT, DV, or MPEG or whatever you need.
Ervin Farkas
www.AtlantaLegalVideo.com
Old January 30th, 2007, 09:52 AM   #3
Thanks, Ervin! I think this will be useful!
Old January 30th, 2007, 10:10 AM   #4
To import in Premiere Pro just rename them to *.m2t
Hse Kha is offline   Reply With Quote
Old January 30th, 2007, 11:21 AM   #5
... and for playback, use the VLC player at www.videolan.org.
-Steve
Steven White is offline   Reply With Quote
Old January 31st, 2007, 12:44 AM   #6
MPS Digital Studios
And, FYI, HDV is officially compressed via mpeg2-ts, which is different in some ways from DVD compression of mpeg2, as the ts is "transport stream."
heath
My Final Cut Pro X blog
Heath McKnight is offline   Reply
