EDIUS 4.6 Upgrade and Sorenson Squeeze at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 28th, 2008, 04:35 AM   #1
We have a confirmed problem with the two products .... GV does not want to acknowledge the problem because they don't have Squeeze.
Basically, before EDIUS 4.6 upgrade, Squeeze works fine. After you put in EDIUS 4.6 upgrade, Squeeze will show its video upside down. It will initially (but very briefly) show it correctly oriented - then it flipped it upside down. If you attempt to encode the resulting video, it will also be upside down.
Please take note of the problem - which we have no fix right now.
We can sidestep it by using Procoder 3 or Procoder Express - but, this means Squeeze can't be used once you upgrade to version 4.6 of EDIUS.
TingSern Wong is offline   Reply With Quote
Old July 2nd, 2008, 07:15 PM   #2
Thats really odd.
I have EDIUS 4.6 and Squeeze 4.5 on the same machine and they behave perfectly together, just to let you know it can be done....
Dave Gosley is offline   Reply With Quote
Old July 3rd, 2008, 07:57 AM   #3
Count your lucky stars then. GV has acknowledged it was their problem. And a fix is already published.
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
