Will Procoder accept Cinefrom as an input file at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old August 12th, 2009, 05:18 PM   #1
I use Vegas Pro 8 with Cineform NeoScene. Will Procoder accept Cineform encoded files as the input file format? The target output is MPEG-2 files for DVD authoring.
Jim Snow is offline   Reply With Quote
Old August 12th, 2009, 05:37 PM   #2
Jim,
I just transcoded a couple of Cineform files
(Prospect HD 1080 50i; target: MPEG 2)
with Procoder 2: the answer is yes.
Best
Vasco
www.donesmedia.net
bricioledamerica.blogspot.com (in Italian)
Vasco Dones is offline   Reply With Quote
Old August 13th, 2009, 12:52 PM   #3
Procoder will accept ANY video file as long as the codec is installed on the PC.
Ervin Farkas
www.AtlantaLegalVideo.com
Old August 13th, 2009, 06:25 PM   #4
I had problems opening FLV files a while back. Do they work for you?
Richard
Richard Hunter is offline   Reply With Quote
Old August 14th, 2009, 06:00 AM   #5
OK, well... uhm... you are right... I can't open them either.
Might have to do with the fact that Flash is considered exclusively a delivery format with a very narrow usage in webpages. On a second thought it might have to do with copyright protection - Flash files may have a "flag" that prevents legitimate transcoders from opening them (hence the reason you need some shady software with questionable legality to transcode them).
That would explain why Procoder can't even open Flash files produced with... Procoder. The codec is there, but something prevents it from being used. Just my speculation though...
Ervin Farkas
Old September 28th, 2009, 06:20 AM   #6
yes you have to make a difference between codec (the ones that windows understands) et formats that can be opened with few readers.
FLV is not a codec but a container, and it can contains some mpeg4.
quicktime is the same, it is a container. Avi is the same, and you need mediaplayer top en an avi or wmv file.
some codecs are embedded into applications (like flash or quicktime) , other have a public interface like divX, mpeg, DV, HDV.
for example VLC reads almost any files without using any external codec, they are all built in.
in your case, you can find many utilities that con convert flash to avi.
(total converter, super, flash2avi , some flv players etc...)
Giroud Francois is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
