Canopus ADVC-300 Converter at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old January 6th, 2012, 07:04 AM   #1
Would the Canopus ADVC-300 converter provide a significant improvement over a software-based solution for improving captured analog video quality?
By software I mean using Neat Video for noise reduction and some of the Vegas filters, like levels.
Thanks...Alan
Alan Henderson is offline   Reply With Quote
Old January 7th, 2012, 07:26 PM   #2
Re: Canopus ADVC-300 Converter
There are two significant differences between the 300 and the 100/110:
It has a time-base corrector (TBC).
It has proc amp controls for brightness, contrast, sharpness, hue and saturation, and some others.
The TBC will reshape poorly timed video frames. This was sometimes a problem in analog recordings. If your tapes show this inconsistency of frames, black frames, show blanking that should be off-frame, then a TBC is the ticket, and the ADVC300 is about the least expensive way to get one.
For all those other picture/sound adjustments, you can correct in an NLE.
In some cases, workflow might be more efficient if picture adjustments are made during capture, eg. if you are digitizing many tapes that you'd rather not color correct in Vegas, but just want to burn straight to DVD or something.
Old January 9th, 2012, 10:09 AM   #3
The ADVC-300 is apparently no longer available. Did a Google search and none available from dealers, or Amazon, or even Ebay!
Jeff Pulera
Old January 9th, 2012, 03:00 PM   #4
Do hardware corrections look better than software corrections?
Old January 9th, 2012, 10:06 PM   #5
In my opinion, not having done such side-by-side comparisons, no. In fact, you'll get finer control for CC with more controllable parameters in an NLE.
OTOH, if you need a TBC, hardware is the way to do it.
Old January 19th, 2012, 12:53 PM   #6
The ADVC-300 is apparently no longer available"
As of today, Grass Valley still lists the ADCV300 (no dash) it as a current procuct ontheir web site, although B&H Photo/Video says it is discontinued. There has been no note of discontiuation in the GV forums supporting the ADVC products.
In any case, used units are often offered on E-Bay.
Its TBC is a line TBC, it can help reshape bad sync from a VCR, but effectiveness depends on what is wrong with the input signal. Similarly within its capability it provides real time correctinon to the input signal and provides an output that emulates a DV camcorder to most capture software. I can provide a faster workflow than analog capture followed by correction using NLE filters and plug-ins. Whether or not the possible corrections meet your needs without further work in a NLE will depend on the source mateial and your client's expectations.
Overall I would say it is a capable and convenient unit at its price point.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
