Adding a Transition That Affects Both Left and Right Clips at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old January 16th, 2012, 10:57 AM   #1
This seems like a no-brainer but I can't figure it out.
If I look at online tutorials, clips that are next to each other on the timeline do not have little triangles where they meet. Mine do.
With these clips, a transition can be dragged to where the clips join and the transition affects both clips.
In my window, the opposite takes place.
I can only drag my transition to the left or right, not to the middle where both clips will have the transition.
What am I missing here?
Alan Henderson is offline   Reply With Quote
Old January 16th, 2012, 11:05 PM   #2
Re: Adding a Transition That Affects Both Left and Right Clips
those little triangles indicate the end of the clip....(or beginning). If you put a 1 second transition between 2 clips you have to have 1/2 second of time on each end of the clips that the transition is placed on. So cut a bit off of the ends of the 2 clips you want the transition on and it will work.
Mark
Mark Slade is offline   Reply With Quote
Old January 16th, 2012, 11:31 PM   #3
alternatively, use AB style editing
http://www.videoproductions.com.au/e...ransitions.png
Anton Strauss
Anton Strauss is offline   Reply With Quote
Old January 17th, 2012, 07:01 AM   #4
Thanks for your suggestions.
Got it figured out.
Alan
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
