ADS converter api555 vs Canopus 110, at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old August 6th, 2006, 05:46 PM   #1
HI
Has anyone done any tests comparing the quality of the analog conversion on the ADS api 555 vs the canopus 110 or any of the other standalone converter boxes. Any comments on other than convenience, the quality difference vs simply using the analog in to dv out on a camcorder?
Sharyn
Sharyn Ferrick is offline   Reply With Quote
Old August 8th, 2006, 10:45 PM   #2
Douglas Spotted Eagle did some testing with several analog-DV adaptors a few years ago, results here http://www.sundancemediagroup.com/articles/ADSlink.htm
On the basis of this I bought a Canopus ADVC100, which I've been very happy with. I understand that the 110 is the same codec. Not familiar with the latest ADS products.
Canopus also has the ADVC300, which includes a timebase corrector, handy if you're transferring old VHS that might have been poorly recorded.
Old August 9th, 2006, 02:33 AM   #3
IF you use analog to digital in a camcorder with TBC
Thanks Seth, Interesting link. DSE does the usual good job.
This then leads to the next question. The SONY digital 8 line have a built in TBC, Do you or anyone else know if the TBC function is in the data path with analog in to dv out, or is it only in the path from the hi 8 tape?
Sharyn
Old August 9th, 2006, 11:18 AM   #4
No idea about whether you'd get TBC using Dig 8 as a pass-through device. If you could find a repair tech with a service manual it would probably be pretty easy to determine...
Seth Bloombaum is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
