stupid mistake! at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old February 16th, 2007, 09:17 AM   #1
stupid mistake!
hi guys,
I did a really stupid mistake. The clips was shot in 25fps with my JVC Hd100. But the first project setting is 30fps.
i did the setting for the other project is fine ,25 fps. So I can't combine the first project and the other together, cause i want to combine all the sequences together.
Is there anyway to change the setting project from 30 fps to 25 fps?
Is there anyway to export the sequences from Edius to After Effect ? Cause Edius has lack plug-in which support for it. Magic bullet can't work with Edius.
Trung Dau is offline   Reply With Quote
Old February 16th, 2007, 11:33 AM   #2
Trung Dau,
1.you can export your file as 25fps using procoder express and incorporate the rendered avi into your other 25fps project.
2.Export the clips you will use in AE as an avi file using canopus HQ codec. After efects recognizes HQ.
Ted Ramasola is offline   Reply
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
