Exporting HDV back to tape on Canon XH A1? at DVinfo.net
Go Back   DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
All flavors of Edius; other Grass Valley / Canopus software & hardware.
Old April 4th, 2007, 05:30 PM   #1
I am actually a Premiere Pro 2 user, however I need to find out if anyone has successfully exported from their NLE back to the Canon XH A1 camcorder a 1080 HD project?
You need to export at least a 10 min clip as shorter length will not test whether the camcorder stops recording after 4.5 min to 6 min (in Prem Pro 2).
Bill in Ohio
Bill Ritter is offline   Reply With Quote
Old April 5th, 2007, 08:49 AM   #2
Ruler of the DownUnder UnderWorld
Only use a Sony HDV FX1 and A1 this end.
Paul Wags is offline   Reply With Quote
Old April 6th, 2007, 11:11 AM   #3
I was able to get Edius to export back to a Canon HV10 without any problems. Seems like the A1 should be the same.
MW
Matthew Wilson is offline   Reply With Quote
Old April 6th, 2007, 08:03 PM   #4
Matthew:
Thanks for the input. Was the export longer than 10 minutes?
I assume it was in 1080 60i?
Bill in Ohio
Old April 11th, 2007, 01:32 AM   #5
HV10 works for longer than 6 minutes and I can confirm that Edius can export to the A1 in 1080i for more than 10 minutes without problems. I haven't tried 24p yet.
MW
  You are here: DV Info Net > Windows / PC Post Production Solutions > Grass Valley / Canopus NLE
