HD10 Component out. at DVinfo.net
Old December 13th, 2003, 08:55 PM   #1
HD10 Component out.
I just read Steve Mullens HD10 Sept2003 review, and noticed this.
"The JY-HD10 is the first prosumer camcorder to offer analog component output. A bundled YPrPb cable (with three RCA plugs) supplies analog component output for all recording formats. A Playback menu lets you select the type of component output you need."
Is this the same componet out that is standard on $10,000+ cams?
Is there any limits or restrictions to using this componet out?
Ken.
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline   Reply With Quote
Old December 14th, 2003, 10:54 AM   #2
There is component out on the JVC Cameras. It is supplied just as Mullen says it is.
Component output is a standard feature of many professional video decks and can be found on many cameras.
This is the first camera at this price level that I know of that does this.
Careful though, this is Analog component and if you want to interface with an HD editing card, they currently all require SDI.
I hope this helps
DBK
Darren Kelly
Darren Kelly is offline   Reply With Quote
Old December 14th, 2003, 11:22 AM   #3
Thanks Darren.
So component out will not be limited to SD resolution like the y/c?
So the order would be Component out- SDI - HD card- for proper uncompressed out to disk.
Ken.
Old December 14th, 2003, 01:00 PM   #4
<<<-- Originally posted by Ken Hodson : Thanks Darren.
Ken. -->>>
No the component out is HD component, not SD
To edit uncompressed:
Component out of the camera into a HD Component-Component SDI converter into an Uncompressed HD editing card.
The converter is the expensive part of the equation. It will set you back about $2.5K
DBK
Darren Kelly
Old December 14th, 2003, 05:30 PM   #5
Thanks for the help.
Ken
