How to manually change extension? at DVinfo.net
Old July 31st, 2004, 03:15 PM   #1
How do I manually change an extension from .mpg to .m2t?
Mark Paschke is offline   Reply With Quote
Old August 2nd, 2004, 12:14 AM   #2
Click on the filename once to select it. Click on it again. A small edit box opens. Use the backspace key, or type the new filename.
Click once....click once more....is NOT a double-click.
Old August 3rd, 2004, 10:23 AM   #3
RED Code Chef
Or hit F2 which is rename. Or select File -> Rename
Rob Lohman, visuar@iname.com
Old August 4th, 2004, 10:19 AM   #4
go to www.download.com
download "AF Rename Your Files" software.
try it (shareware).
very useful whe you have to change extensions for a large amount of files.
hope it helps you.
Alberto Suarez is offline   Reply With Quote
Old August 4th, 2004, 01:46 PM   #5
Thank you much guys, I didnt need to change my ext anyway it was my mistake that I didnt render to transport in Vegas from the beginning
