MPEG1 cannot handle "heavy editing" at DVinfo.net
Old February 14th, 2005, 03:14 PM   #1
I read posts about people saying that the MPEG1 audio is fine but cannot handle "heavy editing".
Could someone please enlighten me as to what would constitute heavy editing?
Greg Jacobson is offline   Reply With Quote
Old February 14th, 2005, 03:52 PM   #2
Any sort of processing is going to degrade the information further. It's important that you convert to an intermediate format such as wav or aiff as soon as you've captured. Cineform muxes this as a pcm format when you capture, I'm not sure how Lumeire does it, but once it's converted, for the most part you'll be just fine.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old February 14th, 2005, 09:57 PM   #3
DSE, you used the word "muxes" when you said that Cineform converts to PCM. So am I correct in understanding that this is not ideal? Not sure if I am following you on that one.
Also, after you convert to a wav file it is ok to edit the audio without degrading it or are you saying that it is degraded only you leave it in mpeg1?
thanks
Old February 15th, 2005, 09:02 AM   #4
Contributor
I think what he meant is that Cineform demuxes the stream and audio gets written to a seperate linear file. Mux and demux are terms that come from the telecom industry, and they refer to multiplexing, which is the combination of various signals into a single signal, and demultiplexing which means going the other way around.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old February 15th, 2005, 10:30 AM   #5
CTO, CineForm Inc.
<<<-- Originally posted by Greg Jacobson : DSE, you used the word "muxes" when you said that Cineform converts to PCM. So am I correct in understanding that this is not ideal? -->>>
Techinically it is ideal. Demultiplex and decompressed audio is stored in a 16bit lossless form, this is the form is must be in if your are to hear it and make any enhancements.
Old February 15th, 2005, 09:37 PM   #6
<<<-- Originally posted by David Newman : <<<-- Originally posted by Greg Jacobson : DSE, you used the word "muxes" when you said that Cineform converts to PCM. So am I correct in understanding that this is not ideal? -->>>
Techinically it is ideal. Demultiplex and decompressed audio is stored in a 16bit lossless form, this is the form is must be in if your are to hear it and make any enhancements. -->>>
Ok thanks David, Looks like I am going with the Premeire Pro bundle with the Aspect HD. As I understand it, I also get to use Connect HD with Vegas if I buy Aspect HD. That is what I read in the forum on your site.
Old February 15th, 2005, 10:56 PM   #7
CTO, CineForm Inc.
That is correct, Connect HD is a subset of Aspect HD (AHD has all of CHD plus much more.)
