HDV and DV Workflow? at DVinfo.net
Old February 21st, 2005, 05:36 PM   #1
Presently using Adobe Creative Suite, Aspect DV, and Cinema Craft Encoder Basic, 1080i footage and standard DV 4 x 3 footage.
Is there any workflow that will produce both 16 X 9 and 4 X 3 Mpeg files. I tried it once and received 16 x 9 letterbox on my wide screen tv and 4 x 3 with different position placements than were in the Premiere project.
Any help is appreciated.
Jim Montgomery is offline   Reply With Quote
Old February 21st, 2005, 06:19 PM   #2
OK you are going to need to spell out your problem more clearly for us to help.
You are saying you have projects that contain 'both' 16:9 1080i and 4:3 480i footage. Do you mean the two types mixed together in a project, or separate projects of each type?
Then, you say you want to produce "both" 16X9 and 4:3 footage from the "same" workflow. CCE can certain encode both, so yes you can... if that is what you are asking?
Care to expand a bit on your question?
Old February 21st, 2005, 07:33 PM   #3
Expounded
I have both 16 x 9 1080i and 4 x 3 480i footage in the same project. After scaling both types of footage to "fit" the layout window and circumstance, zoom, keeping a jumping fish in frame, etc, I would like to be able to output the project in both 16 x 9 and 4 x 3. These footages would then be imported into Encore to author one dvd to handle both television types.
Jim
Old February 22nd, 2005, 03:31 PM   #4
Figured it out (I think)
Import 1080i with Aspect
Import 480i with Windows AVI DV codec as 4:3
Opened a new project in Premier in 16:9
Edit, scale, etc. to fit monitor window
Export 16:9 with CCE
Export 4:3 with CCE
Seems to work, burning a disc from Encore now.
Jim
