Best way to downconvert HDV? - Page 2 at DVinfo.net
Old May 27th, 2005, 12:07 PM   #16
Field Order
Graham
When you convert CFHD to m2v with Procoder, do you set Procoder for "lower field first" for the m2v?
Bob
Old May 27th, 2005, 12:49 PM   #17
Images: 57
Originally Posted by Steven White
However, my experience so far has been that Premiere Pro does not handle this step very well - it has the tendency to bugger the fields or simply ignore them.
I just deconstructed SD renders to ensure proper handling of the fields, before doing the render to m2v.
-Steve
What? PPro can't properly write CFHD to m2v? It has to be third party or requires an interim file (i.e. avi and let encore do the transcode?)
Pete
Peter Ferling is offline   Reply With Quote
Old May 27th, 2005, 04:56 PM   #18
Peter
The problem, as I understand it, with going CFHD>avi>m2v is that you downsample that nice CFHD 4:2:2 color space to DV 4:1:1, and then resample again for DVD to 4:2:0. Ideally I'm looking for a workflow that preserves as much of the HiDef HDV color sampling as possible. The object is to produce SD DVDs that are better looking than a project shot on standard DV.
Bob
Old May 27th, 2005, 06:34 PM   #19
Images: 57
I was refering specifically to PPro not be able to properly render a CFHD file straight to m2v. (Which Steven seems to be indicating). This would effect creating DVD's straight off the time for preview, or having to create and intermediate file that can transcoded by a third party ap.
Steven indicates that such is a limitation of PPro.
Do I understand this to be correct?
Pete
Old May 27th, 2005, 06:52 PM   #20
Robert - yes. I usually start with one of Procoder's bundled DVD presets and tweak it. All those presets (whether for NTSC or PAL) specify lower field first.
Old June 9th, 2005, 07:03 AM   #21
FX1 HDV->DV into Premiere
I am shooting in HDV on an FX1 capturing to Premiere in DV (I'm waiting about a year before I upgrade to a computer capable of the HDV workflow).
Premiere's Media Encoder Presets are all defaulted to: Field Order=Lower. The footage I have been shooting and rendering to .m2v has been coming out as a little pixelated around the edges of objects when I pan or shoot moving objects, BUT I was using the Preset that was 1 pass 7mb CBR High Quality (it said high quality, and 7mb was the highest number, must be the way to go, right? uhh right??).
Having just learned how to create a custom preset (I reccommend Adobe Premiere Studio Techniques Book and accompaning DVD) I created one that was 16:9 NTSC VBR High Quality 2 pass, Field Order=Upper. There was an immediate quality improvement, major, no pixelation. However, there is one section in the video that has a rather quick pan, during this section the whole screen has a rapid side to side movement creating a blurry effect (as if you took a copy of the footage, moved it a 1/2 inch over, and strobed them both through each other).
The book made me aware of Field Order and the difference between VBR and CBR. Was my improvement strictly due to switching to VBR 2 pass and was my jittery side to side motion on 1 of over 15 shots caused by switching to upper field order? I switched the encoding preset field order to upper after reading HDV had an upper field dominance. However, I can't find any info that states if that dominance is preserved or reversed when you downconvert from HDV to DV from the camera into Premiere. I am currently rendering the same file with a lower field dominance with my fingers crossed, but I wanted to bounce it off more experienced minds.
Chad Eller
Chad Eller is offline   Reply With Quote
Old June 9th, 2005, 07:27 AM   #22
MPS Digital Studios
I don't think you can wait a year--you may want to get www.cineform.com to help out.
heath
My Final Cut Pro X blog
Old June 9th, 2005, 02:01 PM   #23
My understanding of the Z1 is that if you record 60i HDV and use in-camera downconversion to NTSC DV, the firewire output meets the technical specs for NTSC SD DV: 480x720, 60i, 4:1:1 color, and field order lower field first.
I have not read any posts of problems with, or need to switch field order when outputting NTSC DV.It should just capture into your system like any other DV source.
Bob
Old June 13th, 2005, 09:42 PM   #24
HDV-DV from Camera, Premiere custom preset
Through trial and error I've discovered the best preset settings (to my knowledge) to create .m2v files if you are going to downconvert HDV-DV from the camera into Premiere is:
NTSC 16:9, Quality=high, 2 pass VBR, field order=LOWER
Premiere does not have a high quality 16:9 preset configured so you have to create a custom preset to get these settings.
I still dont know about bitrates and have left the default settings:
Min bitrate= 15000 low quality
Target bitrate= 60000 med quality
Max bitate= 80000 high quality
M frames = 3
N frames = 15
I really want to try the capturing with Cineform's Aspect HD method recommended by Steven White, however I'm currently financially way over my head. Sony offered no interest, no payment till May 06 on a FX1, an offer I couldnt refuse. I've been making some money but I've been spending it on accessories (Bogen 501 head, Beachtek XLR box, Audio Technica shotgun, etc.) I've got to stop spending on goodies(i.e. Aspect HD) until I get the camera paid for (27% interest kicks in in May).
If anyone has any feedback on the bitrate and M, N frames I would appreciate it.
Old June 14th, 2005, 07:57 AM   #25
Wow, seems like we're jumping through a lot of hoops here trying to achieve the simple result of converting HDV material to MPEG2 output. I'd be interested to know if this is an inherent problem for all editing software due to field order issues between HDV and MPEG2, or simply a weakness in the standard encoding options available in Premiere Pro. I can try running some encoding tests from an HDV timeline in Edius to see how well that works; anyone here using Vegas, Edition, Ulead or Final Cut Pro want to try it in those programs?
My preference is always to use the simplest workflow which yields acceptable results. If I can capture and edit HDV and encode directly from the timeline to MPEG2, that's what I'll do unless some other solution is visibly better to casual observers.
Old June 14th, 2005, 07:29 PM   #26
Huh? HDV is MPEG2... the conversion that appears to be causing some concern here is the 'down-conversion' from HD 1080i to 480 (576 for PAL). From my personal perspective, your observation of "a weakness in the standard encoding options available in Premiere Pro" certainly proved the case with handling HDV.
I now use Vegas for all my HDV material (in conjuction with ConnectHD), as HDV support (that's not capture support!!) was added. Rendering Options are also a little easier to access and understand in Vegas... but that's just my opinion.
A CFHD/m2t/mpg HDV clip loaded into Vegas will be correctly recognised.
Of course, producing a DVD compliant MPEG2 is a different matter... The best settings for rendering DVD compliant MPEG2 have been covered many times on the forum, and a search should yield what you're after.
Steve Crisdale is offline   Reply With Quote
Old June 14th, 2005, 09:06 PM   #27
When I rendered the 480p60 to 480i60 I made the field order lower field first just to be sure. I didn't do an experiment with upper field first, so I don't know if it would playback properly or not.
-Steve
As long as the encoder knows that the source is upper field first it shouldn't matter whether the mpeg is made upper or lower...most modern DVD players don't care if the mpeg it is upper or lower....really old ones needed upper but my guess is 98 percent of the players now don't care.
Randy Donato is offline   Reply With Quote
Old June 14th, 2005, 09:24 PM   #28
Steve: you listed several steps you're going through to convert 1080i HDV to 480i MPEG2, which in theory should be a simple and straightforward process. That's what I'm trying to understand: is there any software which can do this effectively from the timeline without a lot of intermediate steps? Like I said, I can test this in Edius but would like to know what results people are getting in other software.
Old June 15th, 2005, 10:48 AM   #29
I can encode from the premeire timeline from cineform to dvd mpeg2 using Procoder or Main Concept, both of which let me choose field order from there plug-in menus.
My problem is that the 16x9 widescreen dvd output looks very soft compared the cineform orginal.
I think I may be having colorspace issues, but I do not know what the FX1-cineform-premeire colorspace workflow is, or if it is even consistent.
I do not want re-edit in vegas just to fix this - or does a program like automatic duck exist to help one load a premiere project in vegas?
Canon C100, 5D3
Jeff Baker is offline   Reply With Quote
Old June 15th, 2005, 06:21 PM   #30
I thought I'd put to rest (at least for me) the software down-conversion vs. in-camera DV conversion debate by doing a test. Here is the frame I chose:
http://s94963366.onlinehome.us/HDRFX1/softvincam.bmp (2 MB)
The top image uses the software down-conversion I outlined earlier in this thread:
- Capture 1080i HDV, in this case to Cineform Large via HDLink from AspectHD 3.1*
- Place 1080i HDV in a 59.94 fps timeline in Adobe After Effects 6.5 Pro
- Interpretation Rules: set upper fields first, deinterlacing at best quality
- Render to 720x480p60 uncompressed file.
- Place uncompressed file in 720x480p60 timeline
- Render to 720x480i60 uncompressed (click field render - lower field first, conform to 29.97 fps).
The bottom image was acquired using the in-camera DV down conversion.
My analysis
Looking at the images in the interlaced format presented doesn't show much obvious difference... most notably, you will see a slight difference in contrast and saturation - I believe this is due to the color space conversion YUV.709 and YUV.601. This image is a 24-bit RGB bitmap. I did not perform any colour correction.
The main flaw with the in-camera down conversion is the re-compression of the image to the DV codec. The DV codec both spatially compresses the image, as well as resamples the colour space from the essentially 4:4:4 available to 4:1:1. This generational loss is easily apparant in the bottom image.
For example, the neck of the goose is in essentially a black and white part of the image, and is a very sharp transition. If you zoom in on the neck in the top image, it looks quite clean. Zooming on the bottom image reveals considerable mosquito noise around the edge of the goose's neck. It is noticable in both the black of the neck, and the grating in the background.
To demonstrate how offensive the colour resampling is, have a look at some of the longer blades of grass in front of the goose. On the top image the green is clearly confined to the grass. On the bottom image - in particular, in front of the goose's body, you can see the green spilling over onto the goose. Again, this is everywhere, but you have to look for it.
Now, imagine that you're taking this image to an MPEG-2 TS for DVD. At this point, you will re-sample the colour space to 4:2:0 and do more spatial compression. It seems obvious to me that the upper image has a lot more information to provide to the compressor, and ought to result in a significant improvement in image quality - whether perceivable during real time display or otherwise.
-Steve
*Yes, this is an inherently lossy compression. But compared to what the DV codec did, it's irrelevant, and it is significantly easier to work with. If the reader wishes, they can prove to themselves that the Cineform solution is worthwhile.
**Note that no intermediate renders were to compressed formats. All images were rendered to 24-bit bitmap sequences.
Steven White is offline   Reply
