I hate spiders at DVinfo.net
Old November 1st, 2009, 11:44 PM   #1
I hate spiders
I never liked them but I hate em now!
I must have moved through a web outside and I've only noticed when I checked the footage
it's just a short sequence but you can clearly see the 2 spots toward the end.
I think there's at least 15 minutes of footage after this in various locations and evening & bridal gowns - I didn't notice it on the steadicam monitor.
I have a feeling this is going to be a pain, but I'm not sure of the best way to eliminate or at least minimise the damage. It's a promo for a bridal gown maker shot at a local resort.
any suggestions??
Cheers - Paul M.
www.perbenyik.com
Old November 2nd, 2009, 05:34 AM   #2
It could have been worse - it might have been a Black widow.
Alan Craven is offline   Reply With Quote
Old November 2nd, 2009, 11:25 AM   #3
If you can crop the offending area in your NLE, that's one way.
More laborious: if you have access to Photoshop Extended, you can import the clip (make a sub-clip with just the problem frames, my copy will only import 500 frames max, ymmv). Each frame becomes a separate layer in Photoshop, and you can (long, tedious thing) rotoscope each frame with the clone or healing tools to eliminate the problem, then export as a video clip.
Probably not what you want to hear. Someone may know of an easier fix in After Effects, I'm not up to speed on AE but suspect there's masking or something that could be applied. HTH / Battle Vaughan
Old November 9th, 2009, 02:58 AM   #4
Most people try put their videos on the web, and you managed to do the opposite? :-)
Anyway, the video's not visible now.
If the offending defects are lines, it might be possible to fix them with After Effects, using the same tools used to remove wires from special effects shots. The wire removal tool that comes with AE isn't very sophisticated. There are other plug-ins but they're not cheap.
If the defects are stationary within the frame then tracing the defects and having AE remove them can be relatively simple.
But if your camera's image stabilizer was on, then trying to track the defects and remove them could be painful.
Dean Sensui
Old November 11th, 2009, 05:11 PM   #5
I'm working on learning AE, here's some information you might find interesting...I had an inkling it could be done....http://help.adobe.com/en_US/AfterEff...597-7c7fa.html /Battle Vaughan
