WD Caviar Black 2TB heat issues at DVinfo.net
Old September 8th, 2011, 08:53 AM   #1
Hi all,
Going to Wales for a year, leaving my desktop behind... I'm taking with me a desktop replacement, and I just bought a 2TB Caviar Black to use as an external work drive (I have no need for raid at the mo).
I bought a generic external enclosure (a Raidon e-sata\usb3) which is from aluminum, which I thought would be enough, but using a HD monitoring utility I see drive temperature quickly rise to around 53-54 Celsius, and it remains there even when the drive goes idle.
I imagine the caviar black is exceptionally power hungry compared to other drives... Should I go through the trouble of replacing the enclosure with one with a fan, or am I making too much of a fuss over this?
many thanks in advance
Jon Shohet is offline   Reply With Quote
Old September 17th, 2011, 06:52 AM   #2
Re: WD Caviar Black 2TB heat issues
Lucky for you Wales is much cooler than Israel. Nevertheless, your current temp is pretty high. Depending on the casing you have, one of these products may be interesting. Unfortunately I only have it in Dutch, but maybe it will help.
See Hardeschijfkoeling | Core | Tweakers.net Pricewatch Prijzen
Old November 5th, 2011, 02:56 AM   #3
Harm, many thanks for your reply. Sorry for not saying so earlier, I've been insanely busy for a while, not writing anything on the forums through out. I hate it when I take the time to answer someone and he just disappears without any acknowledgment, so again, thanks.
My enclosure is tight and slim, so the only relevant cooling solution would be probably one of the "Hard drive carrier" fan shelves that the entire enclosure would rest on. (sort of like laptop cooling solutions just for a hard drive enclosure). I'll look to see if I can find something like this in my part of the world.
The good news is that while the temp reached around 54 while initially copying the large amount of data onto it, when actually being used to edit, it seems to peak at around 50. Still not great, but I think I can live with it if I don't find a good external cooling solution.
Cheers...
Old November 5th, 2011, 07:29 AM   #4
I would think you need an enclosure with a fan. Another alternative would be one of the docking stations where the drive is not contained Newegg.com - Thermaltake BlacX ST0005U External Hard Drive SATA Enclosure Docking Station 2.5” & 3.5” USB 2.0 & eSATA
Old November 5th, 2011, 04:18 PM   #5
Thanks Mark. I actually have a one of those docking stations, but they are a plasticky affair, and I have heard some horror stories of drives getting so hot during heavy operation that they had melted the plastic on the dock. It's also not an ideal solution for editing on the go, which is something I have to do now frequently.
I chose my current enclosure because it was the only one I found that has both usb3 and esata, which I find very handy. I suppose I could just buy a new one with a fan and settle for just usb3... but while I know 50 Celsius is a bit too much I'm not sure it's that disastrous..?
