How can i get this old LUT .xls into Resolve or Apple Color 1.5?
I have an old .xls file from the mid 2000s that was made with information correcting Film_Rec from a Varicam camera. I'm trying to figure out how to get this information into either Davinci Resolve Lite 11 or Apple Color 1.5 to use with Film Rec material.
Go Go Godzilla
Re: How can i get this old LUT .xls into Resolve or Apple Color 1.5?
I just had a lengthy discussion about LUTs with a close friend who manages the edit teams at LinkedIn. We both agree, LUTs are basically modern-day eye-candy to sell product or add-ons.
The problem with using any LUT is that you're literally adding a color filter into a timeline or as part of the finishing process, rather than using classic color-correcrion techniques to create your final look. It's like using any auto feature on the camera, it won't fix problems and gives the novice a false sense of security that the automation will "just work" and look good. Best advice is to learn proper color correction and finishing techniques and if need be, create presets in your NLE to replicate the look consistently in your timeline. There are deeper reasons LUTs are counterproductive but that's a long conversation. |
Vortex Media
LUTs are extremely useful as a first step in color grading, particularly if one has shot with LOG or RAW. Obviously, dropping a LUT on footage is not the end, it's just one part of color grading, but a very important and time-saving tool.
It's also possible to grade without a LUT, but to call LUTs just "modern-day eye-candy to sell product or add-ons" just shows your ignorance. Most LUTs can be downloaded for free and are much more than eye candy. It's funny that you advocate for using presets, but that's exactly what some LUTs are -- just presets.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools Last edited by Doug Jensen; August 2nd, 2024 at 08:09 PM. |
#4 | |
All this becomes a major consideration if you are editing high-end 12 and 16-bit video files. So many people working with these formats are using LUTs that were developed for the 8 and 10-bit world. Using these LUTs can cause major quantization errors. For every brightness or color value in an image, which can change dramatically from scene to scene, has a numerical value assigned for it to be stored into a video file. And for a LUT to work, you need to have a matching value in that LUT for every single value in the image. If you don’t have enough values in the LUT, the nearest available value will be assigned to unmatched values in the image. This will cause artefacts. Because this has become more of a problem in later years with development of cameras with greater dynamic range and bit depth FRAME.IO has issued a web page on their site outlining some of the pros and cons of LUTs and the pros and cons of the ACES workflow. Rather than go over well trodden ground, it's probably best to check out FRAME.IO's page, which fairly concisely covers the subject. All said and done. LUTs are used extensively on movie sets to approximate an end 'look' but 95% of movie post is done using CSTs and the ACES workflows as they are dynamic and not locked to the inflexible values locked into a table. Which is what a LUT is, a lookup table. Using transforms and the ACES workflow ensures that you can extract the maximum values and bit depth out of the footage being graded. For example, with Davinci Resolve. The CSTs in that NLE are based on the exact sensor data supplied by the camera manufacturers to ensure a mathematically correct transfer of that data to a chosen color space. Chris Young https://blog.frame.io/2020/04/27/luts-vs-transforms/ https://frame.io/ |
#5 |
Support your local movie theatre, they need it. |
#6 |
Go Go Godzilla
The guy I'm referring to is the head of live production at LinkedIn. They just spent millions of dollars on creating a near-perfect color correct schema for the entire company so the output color looks correct and proper regardless who's shooting or editing. No LUTs were part of the process.
In fact the color science he created was recently adopted by Adobe and was reelased live to the world for anyone with a current PP license as part of the finishing module. |
#7 |
Vortex Media
If he doesn't want to use LUTs there is absolutely nothing wrong with that. Nobody has to use LUTs.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools Last edited by Doug Jensen; August 10th, 2024 at 05:55 PM. |
