I have a nvidia 7600 gt. I cannot play cineform avi in VLC and mediaplayer shows a horrible flicker if I export in upper field first and a horrible faster motion (almost like a subtle fast forward) if I export in lower field first. I wish I knew what was going on.
Guys, this thread is a year old. Most of the information in it is obsolete. Just to give a few examples...
There were no Intel Macs, they had just been announced at Macworld. There was no XDCAM HD, they started shipping in late March. There were no Core2 Duo processors, let alone quad core. It's likely that the drivers for the graphics boards mentioned have been updated to address any shortcomings. But those boards have probably been superseded by now anyway which is why Marc can't find them. -gb- |
FWIW...
I'm running a core2 duo on an SLI enabled asus mobo. Playback of either m2t or cineform intermediate is seamless, glitchfree. i wouldn't go NEAR WMP with a ten foot boompole. I use Zoomplayer...fully configurable, a wee bit technical, but, that's what makes it great. |
Time limiting will definitely help, go for it.
I saw the date as "yesterday" and did not check anything above that... sorry... |
Question
I have a P4 amd64 3000+(i think is the number hahah) and I have a gig of ram. and I havent had my A1u that long but I have been cutting my footy in Vegas 7 and exporting it out into quicktime movies and the footage looks great me. It plays fine on quicktime and and works good when i send it over the web. is this a wrong move to be exporting to quicktime everyone seems to be using Wmv, or Vlc to play there clip.
When im editing footage I dont seem to have to many problems with play back. Few that I have I tend to blame more on my hard drive that is has never been re formatted since I go this computer in 04. here is a clip of some video I did for this scion dj event at a club, its very low light but is the quality how it is suppose to be https://pantherfile.uwm.edu/dacole/p...v?uniq=-5hqrs2 |
VLC player works just fine on my PC, but I usually just rename the M2T files to MPG so they play on Windows Media Player. I downloaded the latest version of WMP 11 and it works fine too. VLC player is ok but does not have a counter or repeat which irritates me. Windows Media Player just plays them like any other file. There are no glitches with full 1920 x 1080/60i or 1080/24p, except for one about 1 to 2 seconds into the video. This is normal with most files except .wmv files. Nero Showtime also plays the files without a glitch. |
Playing .m2T files
Another a great thing you can do if you have a Firewire-enabled TV (and a Mac, even an old one - I use a G4 Mac Mini for this) is to use the FireWire SDK (the AVCBrowser and Virtual DVHS components) to play HiDef transport streams directly into the TV. Not for the faint-hearted and you need to be an Apple ADC member to get the software but the results are awesome. I've played both 720P and 1080i HDV originated .m2ts without a hitch (obviously the TV does the decoding (mine is a Sony XBR960 34" CRT).
The Lumiere plugin for FCP will let you export the .m2ts. or you can export a file that iMovie will swallow, then 'save as a file for camera later. You need to have an HDV camera plugged in and the file it creates, whilst missing the .m2t suffix, is good to go. |
wmp is problemmatic. i've always used zoomplayer, which has now evolved to a very dependable and configurable freeware player. Zoomplayer will play native m2t video streams after you download ffdshow. If you install Zoomplayer, it will go out and get the codecs you need. Just my $.02.
I recently bought a 22" WS LCD that has both analog and DVI. I had connected the analog cable as my video card had the adapter already attached (I replaced a 19" LCD second head with the 22").
Attached to my ATi Radeon X800GTO, what's the advantage of DVI over analog, if any? |
Time limited threads
jason |
| All times are GMT -6. The time now is 02:10 AM. |
