Confused about capture cards at DVinfo.net
Old July 9th, 2006, 01:36 PM   #1
I was researching the Aja Xena HS card, and am confused about how it works with a NLE. MY software of choice is premiere pro 2.0. I don't have a HDV friendly codec such as Cineform at the moment, as i was researching, i found out that theres no viable pathway for monitoring HD when using cineform... Then I started looking around for c apture cards and found that Cineform Prospect HD and the Xena cards work in conjunction.... My question and confusion is regarding the foreign codecs and where these cards play a role...
Is premiere pro 2.0 with adecent computer and a capture card like the xena all i would need (not including cineform)...? Or is cineform a required ingredient for the mix?
Spike Spiegel is offline   Reply With Quote
Old July 10th, 2006, 10:58 PM   #2
It depends on what you are trying to do...
If you are just trying to edit HDV, then you don't really need the Kona card at all. (or cineform)
Cineform is a codec that helps speed up the editing process, bu you don't have to have it. (but I recommend it) ;)
The Xena card gives you inputs other than just firewire. You can capture to a number of codec, but most people use these cards to either capture Uncompressed footage via the SDI input, or capture straight to the Cineform codec. (which takes up a lot less space compared to uncompressed)
Not sure what you mean by "no viable pathway to monitor HD when using cineform"
You just need a video card that can support monitoring the HD...the same as when editing with most HD footage.
http://dv411.com/quadro540v.html
Jason Murphy is offline   Reply With Quote
Old July 11th, 2006, 03:05 PM   #3
Hi,
when i tried to edit HDV natively, none of the "effects" like video transitions worked... I never rendered it , but none of the effects were showing up when i scrubbed through the timeline...
As for monitoring on a broadcast HD monitor, doesn't the connector type have to be HD-SDI ?
Old July 12th, 2006, 10:46 AM   #4
I checked out the quadro fx 540, is there a better card available either from nvidia or matrox? that seems like the perfect solution... The reason i am confused is that I always thought that HD broadcast monitors only ran off HD-SDI outputs from a capture card like the decklink... I didn't knwo it could run off a card like the quadro 540..
