50i 25fps to 50p 50fps at DVinfo.net
Old December 27th, 2006, 11:27 AM   #1
Hi
I was reading the other day - i forget where - and someone mentioned that with 50i 25 fps PAL you could take 25 fps INTERLACED and take each interlaced field and convert that to a frame giving you 50 fps.
Is this possible it certainly sounds feasible? How do you do it?
Cheers
mat
Oh Yes...
Mathew Hamilton Green is offline   Reply With Quote
Old December 28th, 2006, 12:37 AM   #2
Procoder will do this via menu options.
Virtualdub (freeware) with a smartdeinterlacer plugin (http://neuron2.net/smart/smart.html) works pretty well too...
Old January 2nd, 2007, 01:15 PM   #3
Hi
Thanks for the info!
Where in Procoder can I do what i need to do?
I cant seem to find it anywhere!
Cheers
mat
Oh Yes...
Old January 2nd, 2007, 01:28 PM   #4
Using the standalone version of Procoder, input your source footage ("Source/Add")and check that it has been detected as "interlaced".
Then go to "Target/Add" and specify your output file format. Then go into the Target options dialogue and specify framerate as "50" and interlacing as "not interlaced".
Old January 2nd, 2007, 02:46 PM   #5
Hi
thanks for the reply but I am still having problems..
I can add the QT movie..
I can then change to NON-INTERLACED and then goto ADD and choose QT 6 DV PAL and then when I try and change the fps setting i cant.. 25fps is the only option.
Any ideas?
The max i can get it to go is 30fps when I fiddle around!
Cheeers
mat
oh yes I have got version 2
Oh Yes...
Old January 2nd, 2007, 03:00 PM   #6
DV is a standardized format and 50 frames per second is not within its spec.
On a PC, I would save a something like a Cineform-codec avi or huffyuv-codec avi, both of which allow 50 frames per second. I assume there's a Quicktime/Mac equivalent, or you could save to mpeg or uncompressed.
Old February 1st, 2007, 02:19 PM   #7
After much phaffing here is the solution
http://www.dvinfo.net/conf/showthread.php?t=85425
Cheers
Oh Yes...
