Kessler EZJib or which crane? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old December 1st, 2009, 04:32 AM   #1
Hi what s the best choice for a crane with a z1?I need a remote head too with remoted controls....
Old January 21st, 2010, 01:36 PM   #2
I have used a Kessler. really liked the results. They have a 5.5 and 8ft... I used the 5.5 but wish we had the 8ft.
You can get a motorized head on ebay, they are ok but you really want a pro pan/tilt head.
Jon Kon is offline   Reply With Quote
Old January 21st, 2010, 06:00 PM   #3
I have the Kessler 8ft crane and love it. It is silky smooth and I believe it's double frame construction gives it the most stable shots in this price range.
I bought the ball extender that mounts on the end of the crane and my tripod head mounts to that for when I want to operate the crane from the front end.
I do advise you to spend the extra $50 and get the "brake" option for the crane so you can lock it in a position to simulate a tripod when needed.
I also have the K-Pod tripod and Hercules head that Kessler makes as I wanted a dedicated system.
D.J. Ammons is offline   Reply With Quote
Old February 6th, 2010, 03:26 PM   #4
Can't go wrong with a Kessler
I got the same setup as above.
The 8 ft is only $10 more then the 5.5.
I'm loving it.
http://www.kesslercrane.com/index.ph...=182&Itemid=95
Gerhard Helmut is offline   Reply With Quote
Old February 7th, 2010, 11:34 AM   #5
By "best choice" did you mean smoothest shots? Feels, looks, and performs most professional? Jimmy jib Lite. You can build it to whatever length you need.
Jimmy Jib Lite, Cable Jib & Porta-Jib Conversion
Warren Kawamoto is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
