Best jib for filming in nightclubs? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
Old January 20th, 2012, 07:17 AM   #1
We film a tone of gigs in nightclubs using sliders etc but want to try
Using a crane, clubs are really tight but for big gigs
We get ropes off stage areas so we will be limited to say a 6ft to 8th jib
Was thinking about testing an eBay crane for the hell of it
Or should I straight up use a Kessler?
Has anyone ever used a jib in a club? Will also
Use it for festivals
Matt Shefford is offline   Reply With Quote
Old January 20th, 2012, 07:29 AM   #2
Re: Best jib for filming in nightclubs?
I've just bought the Hague K-12 Multijib, which gives you three different jib lengths of about 4, 8 or 12 feet.
It also depends on the weight of your camera that you intend using on it. It will take up to 14Kg including the pan/tilt head.
TV Director / Cameraman
Old January 20th, 2012, 08:02 AM   #3
I've used a Kessler for shooting videos in night clubs. You can also get enough parts to do a 5', 8', or 12' setup. You may not need 12' for the height but its nice when you want to reach out over things.
You can get some awesome shots flying over the crowd with a jib and a remote pan head.
http://www.LandYachtMedia.com
Old January 20th, 2012, 10:32 AM   #4
For sure, just keep mindful of the liability of doing so:
Dangerous Minds | Some bad mojo at SXSW: Giant camera crane crashes into crowd injuring several people
Charles Papert
www.charlespapert.com
Old March 9th, 2012, 03:44 PM   #5
Check out the Comely Crane. Variable lengths, adjustable in seconds by sliding it. Sets up in about 2 minutes, only 1 part (plus tripod) so no bolts to lose in a dark nightclub, decent mechanical tilt, very easy to balance. I own one, quite decent for a relatively low price. B&H sells them.
Old October 21st, 2012, 08:25 PM   #6
You an use a jib actually. some jibs on clubs are built in and is controlled via technical support. if you will manually control it, it could e very hard.
Andrew James is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Jibs / Cranes / Booms
