J-Log1 and the LS300 - Page 2 at DVinfo.net
Old March 17th, 2016, 01:15 PM   #16
Images: 10
Re: J-Log1 and the LS300
I shot a commercial in Log yesterday and the rushes look OK.
I used 800 ISO after deciding that it must be the native ISO...
I'm using the new spot meter function to take the following readings:
At 400 and 500 ISO the maximum video level is 400%.
At 640 ISO the maximum video level is 566%.
At 800 and beyond ISO the maximum video level is 800%.
Also, if you work below 800 ISO the max IRE level according to the histogram is below 100%.
So 800 ISO does appear to be the sweet spot in terms of the promised 800% dynamic range.
Lower ISO's will of course result in cleaner pictures (although they look very clean at 800 ISO to me) but you won't be using the full 8 bits to record the signal or capturing the full dynamic range that the camera is capable of.
None of this is documented anywhere that I've seen, so I'm assuming I am correct.
Old March 17th, 2016, 04:31 PM   #17
I have two Spectra meters that I occasionally use, but since getting the Gratical X, and ordering the scopes with it, I've found that I can dial in the correct exposure without removing my eye from the EVF.
The waveform and histogram sit in the black area at the bottom of the screen and a quick glance tells me where I am.
Believe me, I'm not a Zacuto fan boy (I don't like many of their overpriced "recoil" rigs) but if you've got the cash, the Gratical is a tool that will travel along to many cameras before it's obsolete (I hope).
Steve Rosen is offline   Reply
