Possible to Customize LS300 File Names? at DVinfo.net
Old July 14th, 2021, 08:02 PM   #1
Doing a weekly production using two LS300s and the cameras are creating files with duplicate filenames. Premiere Pro doesn't get confused by them, but I sure do. I looked for a menu option to modify the file name, (eg. Camera1xxx.mov, Camera2xxx.mov) but have not found one. Anyone know if this is possible? Thanks.
Luke Miller is offline   Reply With Quote
Old July 15th, 2021, 07:22 AM   #2
Re: Possible to Customize LS300 File Names?
I believe the camera menu is nearly identical to my HM-170 cameras. If so, you can achieve what you desire by going under the CLIP NAME PREFIX found under the SYSTEM MENU-RECORD SET.
For my two cameras, I have them set so every clip begins with either CAM1 or CAM2 as the first four characters of the clip name.
Be aware the file type may affect being able to assign clip name prefix.
Hope this helps.
Roger
My YouTube Channel: https://www.youtube.com/channel/UCAp...2AHr_pHFID5LDA
Roger Van Duyn is offline   Reply With Quote
Old July 15th, 2021, 12:42 PM   #3
That was it! Thanks, never would have found it without your help.
