Message for Paul Mogg at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old August 21st, 2003, 06:48 AM   #1
Hi Paul,
I've tried your email adress a few times without success (it seems to be inexistant...) so I will try that thread.
I downloaded virtualDVHS with firewire SDK 17 but it just won't work (DVHScap does though). I was wondering if you could send me the SDK 16 version of virtualDVHS since I cannot find it on apple's site anymore. Do I need to install stuff in order for it to work?
Eric Bilodeau
Eric Bilodeau
video SFX,DOP
___________________
http://www.fictis.net
info@fictis.net
Eric Bilodeau is offline
Old August 21st, 2003, 11:13 AM   #2
Eric, a couple of things. I'm not an expert on this but I had to install the SDK to make virtualDVHS work, which you don't need to do for the other also you have to set the I/O channel to 63, I got this from another thread. I'll check my email adress and see why that isn't working. If you post your email adress I'll send you the SDK 16 if I still have it in a .sit file.
All the best
Paul
Paul Mogg is offline
Old August 21st, 2003, 02:20 PM   #3
info@fictis.net
Thanks Paul, it's very appreciated ;)
Eric
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old August 21st, 2003, 03:14 PM   #4
HDV Cinema
Paul,
I'm wondering why you decided to go with virtualDVHS when it requires you loading a whole new FireWire SDK (with who knows what consequences) when DVHcap does the job and is a simple utility?
Have you been able to output to the camcorer a Heuis encoding?
Steve Mullen is offline
Old August 22nd, 2003, 12:52 PM   #5
Hi Paul,
I haven't heard from you yet, have you found SDK16?
If not just stuff your developper's package, it should do the trick.
Eric
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
Old August 28th, 2003, 05:37 PM   #6
Sorry I haven't got back to you on this, been snowed under with work. I have the SDK 16 and will zip it up and send it to you shortly, unless you've alreay got it.
Steve, I was just trying the VirtualDVHS program out of interest, also it does batches of files which I don't think the DVHScap utility does.
Paul
Old August 30th, 2003, 02:29 PM   #7
I have been able to use VirtualDVHS (finally) and it has an advantage over DVHSCap as Paul said: batch output or track loop output witch are great to look at rushes.
Eric
Eric Bilodeau
video SFX,DOP
___________________
info@fictis.net
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
