Wide angle lens recommendation? at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old September 7th, 2003, 03:14 AM   #1
I am iterested in doing some architectural studies with the JVC HD10u, any suggestions for a quality wide angle lens that won't break the bank?
Fernando Vossa
The real voyage of discovery consists of not in seeking new landscapes
but in having new eyes.
- Marcel Proust
Fernando Vossa is offline
Old September 7th, 2003, 10:43 PM   #2
You might want to try Canon's WD-58H, 0.7x.
I got this for my 52mm GY-DV301, using a 52 to 58mm converter ring.
In both telephoto and wide settings, images are crisp and clear without distortion and you may hook it on permanently.
Yik Kuen is offline
Old September 8th, 2003, 01:34 AM   #3
HDV Cinema
JVC makes a WA for the cameras--at least in Japan. Contact a JVC dealer for a GL-V0752 0.7X.
JVC also makes an underwater housing, the WR-HD1.
Steve Mullen is offline
Old September 8th, 2003, 03:20 AM   #4
Outer Circle
Steve, how does this JVC wide angle adaptor compare with the other wides on the market? Does this JVC wide come with filter threads in the front?
Frank Granovski is offline
Old September 8th, 2003, 11:14 AM   #5
HDV Cinema
I don't have any details on the JVC WA. I suspect it is not available in the USA.
i would go to a camera store and try before i bought.
And I'd go with a 52mm.
Old September 8th, 2003, 10:45 PM   #6
It is quite hard to get the JVC WA lens here, Singapore. It is the same model used for other consumer models such as DV3000
Yik Kuen is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
