HD movies: Distribution - Page 2 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old October 5th, 2003, 01:55 PM   #16
<<<-- Originally posted by Mike Eby : Alex,
I used Womble to convert it to an m2t file and it downloaded to the camera fine. -->>>
Mike, sorry I'm not sure what exactly did you convert to m2t using Womble.
My question was this:
- Can you encode video + 5.1-channel Dolby sound in mpeg2 and then into TS?
From your reply, I understand that you did succeed making a TS (m2t), but from what source? Was your mpg 5.1-channel sound or just stereo?
Alex Raskin is offline
Old October 5th, 2003, 02:07 PM   #17
Alex,
Sorry I was unclear what I did… I encoded an MPEG2 file of edited clips from the MainConsept codex built into Vegas. Then converted the MPEG2 stream to a Transport stream using Womble, then used the DV capture utility that came with the camera to reload it back into the camera. As you said this should also work on D-VHS as this it the method JVC recommends to transfer to and from D-VHS to the camera. This sounds like a PITA but its really not that bad.
Edit:
Ok I understand your question I have to try to encode DD 5.1 then move it back into the camera. This makes sence now. I will have to see how to encode DD in Vegas.
Mike
http://www.acdnow.com
Mike Eby is offline
Old October 5th, 2003, 02:37 PM   #18
Mike, looking forward to your results with a 5.1-channel Dolby mpg file transferred to TS.
This is where I fail as Womble does not like my 5.1-channel audio stream.
Just to clarify, this is what I do:
- In Premiere Pro, I have a video project with 5.1-channel sound track.
- I can encode this project from Prem Pro using the bundled MainConcept MPEG2 encoder (just like you do, I guess). Note that there are 2 streams engaged in the encoding:
1. video - handled by the MainConcept MPEG2 Video encoder
2. audio - handled by SurCode 5.1 Dolby encoder (because MainConvept's Audio encoder can only handle Stereo, not 5,1-channel sound.)
These 2 streams are Multiplexed on-the-fly in Premiere using the MPEG2 Multiplexer (MainConcept or Adobe's code, not sure.)
- Result: PPro seems to complete the task just fine and produces the resulting .mpg apparently with both video (this I checked, it's there) and multiplexed 5.1-channel audio (can't check that).
- Next step is to convert that Program Stream .mpg into Transport Stream .m2t. For that, I use Womble.
- BUT! Woble does not accept the audio part of that .mpg! If I exclude audio stream, Womble accepts mpg for m2t output. If I include audio stream, Womble refuses to output. (Note: Womble accepts similarly encoded STEREO stream just fine, its only problem is with my Dolby-encoded stream...)
- Thus I concluded that either Premire Pro's way of multiplexing the audio into .mpg is non-standard, OR Womble is not even equipped to understand more than 2-channel sound.
- If former is true, you can see whether Womble accepts Vegas's 5.1 multiplexed sound.
- If latter is true, then Vegas' encoded mpg file will fail in Womble the same as PPro's one. I cannot do the comparison myself as I do not have Vegas.
Once you have TS file (m2t), transferring it back onto the tape is no problem at all using the Camcorder's bundled "HD capture/export" utility.
I never even tried to export back to the camera - instead, I always export to D-VHS DH30000 recorder using the cam's utility, and it woks just fine (on video+stereo audio, that is).
My point is this: say you have a surround-sound movie. The current way to play/distribute it is via D-VHS tapes.
The players do support both Dolby surround sound, and HD playback, so if you manage to get such movie onto the tape, playback is no problem then.
I stumbled at the point of mpg into m2t conversion, when mpg has a 5.1 Dolby sound in it.
Let's see what YOUR results will show! If we figure this one out, we get a solution to distribute HD movie with theatrical sound using TODAY's technology.
(Sidenote: let's not discuss WMP9 here, I have no problem encoding in it and love the results, but there's no standalone players that support such playback right now, so let's focus on D-VHS, OK?)
Old October 5th, 2003, 10:16 PM   #19
in response to Dave Largent's crique of my post...
"Lisa, I've been following your posts for a short while. And I've been messing with m2t files for a bit. (Go see my recent post over at the "Open DV Discussion Forum" under the topic "Realtime WM9 encoder cards".)
I notice in your post that you say "far, far too many" have lower-end PCs that can't keep up with the data rates required to play HD smoothly. I don't mean to come down on you, but really, the only ones who can play HD on their PCs are either the ones in our business or the geeks who sit around tweaking their systems. That's what, maybe 20% or less of the market? "
I'm confused...that was exactly my point...that many do not have a high end computer to make WMP in HD work.
"But, remember, the majority
of our clients are still on dial up. A $100 AGP card is stretching it for them. "
Umm, where do you live? I live in Silicon Valley. My clients are IBM, apple, HP, Cisco, ebay execs. I live a few blocks from NVIDIA (you know the people that make AGP graphic cards)and Creative Labs...
" Fine, you had a rich client who would pay for the 100 DVDs you made. That's fine. But from what I've seen from dealing with this all, I would've known going into it that only a small percentage of the 100 are going to be able to play."
I guess I should have prefeced that with "I live in silicon valley". We live in a very different world that most of the country. Hmm...he was guessing that since most of the attendees work in computers (almost everyone out here works in computers...you wouldn't understand unless you lived out here), that they could play the HD files. But he was wrong...they all had problems playing HD on WMP9.
" Just don't know if I could go ahead and take the cash myself. Not to be on you. Business is business. Each has to make up his/her own mind regarding the ethics of it."
I don't see how you can question my ethics. You haven't a clue where I live...Silicon Valley is covered with computer people. You may call them "geeks" , but these "geeks" are all multimillionaire entrepreneurs out here and I call them clients.
Having said that, the point of my comment was that I don't think WMP9 HD is a viable mass distribution format. I agree with Alex Raskin who says,
"let's not discuss WMP9 here, I have no problem encoding in it and love the results, but there's no standalone players that support such playback right now, so let's focus on D-VHS, OK?"
Lisa Lee is offline
Old October 6th, 2003, 03:58 AM   #20
Ken, a couple days ago I was looking into this exact thing you mentioned regarding the affect of the encoding bit rate on video playback. My experience has been the opposite of what you stated. I found that as the bit rate goes up -- and the file size gets bigger -- it becomes increasingly more difficult to get smooth playback. Below is what I found. First column is file type. Second column is notes on image quality of a captured jpeg. Third column is notes on how well the file plays in Windows Media Player 9.
Original m2t___not done___video fine, audio stutters
Uncompressed avi___normal, sharp stills___video and audio stutter on playback
0.5Mbps WMV9___pixilated___plays fine
1Mbps___smoothed___plays fine
3Mbps___sharpness appearing___plays fine
5Mbps___not quite good enough___plays fine
6Mbps___okay___plays fine
7Mbps___good enough___slight video stuttering, audio fine
9Mbps___slight improvement vs. 7Mbps___increased video stutter
15Mbps___?? very slightly sharper___mostly still shots now, but some motion
20Mbps___ no improvement___all stills (no motion), audio fine
Just thought I'd pass it along.
Dave Largent is offline
Old October 6th, 2003, 06:37 AM   #21
Alex, the standalone WMV9 players will be here soon and that'll be it for D-VHS. And the one I've linked to here is not the only one I am aware of.
http://www.gamerscircle.net/index.php?p=1130&c=1
Old October 6th, 2003, 06:46 AM   #22
Wow, that makes so much sense. All this work on blue-ray technology just to perserve the 10 year old out-dated Mpeg2 compression scheme, and here is a superior system that can use existing hardware technology and manufacturing.
Every person I know who has seen WM9, agrees it looks better than Mpeg2. I'm not talking about crippled playback on a mediocre PC, but a clean demo at 60 fps and a bitrate of less than 10Mbs.
Let's get on with this and cut the apron strings.
Jay
Jay Nemeth is offline
Old October 6th, 2003, 10:19 AM   #23
Yah, Jay. Those stills I mentioned in my above post, the ones encoded above 7 Mbps, were not that much different in appearance from the uncompressed AVIs.
Encoding to WM9 does take some time, though. Check this out.
For comparison purposes, on my machine, a simple color correct to 1 minute of footage takes 9 minutes to render. Here we go. To decompress 1 minute of M2T (~170 MB) to avi (~7250 MB) takes 4 minutes. Note here that it blows up 43X its original size! Now, to encode that 7250 MB AVI to WM9 at a video bit rate of 7 Mbps takes 58 minutes! And the resultant WM9 file size is 80 MB which is about half the original MPEG2 size, and about 1% the size of the decompressed AVI -- with not much loss in image quality.
Regarding Blu ray, Sony released one of these player/recorders in Japan in April. Only $3800. The nice thing about the coming WM9 standalones is that they're going to cost only 10% of that Blu-ray Sony. *And* they'll be backwards compatible so that they'll be able to play current MPEG2 encoded DVDs. What these
WM9 standalones are is "the next generation DVD players".
Old October 6th, 2003, 01:19 PM   #24
Thanks for the details Dave. It appears your bottle neck is your HD's. It is obvious your cpu can handle heavy compression yet you have problems when there is little or no compression but large file size. Again are you defraged? All drives are in DMA mode? Are you running a HD RAID?
Ken
Damnit Jim, I'm a film maker not a sysytems tech.
Ken Hodson is offline
Old October 7th, 2003, 01:42 AM   #25
Ken,
Thanks for trying to help. To answer your questions. No,
I'm not defraged, but I will soon. No RAID set up. Do you think RAID would help? Regarding DMA, I don't know if my 160GB 7200rpm drive is in that or not. How to tell? Perhaps you could explain the significance of DMA, as I know nothing about it.
Old October 7th, 2003, 02:01 AM   #26
Has anyone had any experiences they can share regarding outputting their HD to DV/SD for distribution on DVD?
How does the final DVD compare to a professional film which you would see on DVD?
This may be restating an earlier question I raised, but is it better to edit in HD and downconvert to SD for DVD distribution, or take the original HD footage, downconvert and edit as SD instead, with the idea that you may return later and create an HD version?
Brian
Brian Mitchell Warshawsky is offline
Old October 7th, 2003, 09:56 AM   #27
Glad to help Dave.
Rule 1: Defrag all the time! Nothing will degrade your performance faster. Defrag your C:Windows partition and your data partition(s) often. You will also have much better performance if they are seperate drives on seperate IDE channels.
RAID is almost a necessity if you use uncompressed often, although a tidy defraged 7200rpm may be able to handle 1 stream. If you do RAID, leave your C: Windows on a seperate HD.
DMA is a HD mode that will allow much greater data transfer rates. To check if enabled (I'm assuming XP here)
System/Device Manager/IDE ATA ATAPI Controllers/Primary Channel/(right click)Properties/Advanced settings/ - Change Transfer Modes- to DMA if available for device 0 and 1
Do the same with Secondary IDE channel.
Ken
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
