New HD DVD Player! - Page 2 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 13th, 2004, 08:44 PM   #16
Re: Archive and reload FCP edited footage
<<<-- Originally posted by Maury McEvoy : I archive edited sequences from FCP using:
FCP > File > Export > QuickTime Movie > Make Movie Self-Contained.
Maury what codec are you using for export?
I believe my version of FCP defaults to DV-NTSC
Paul St. Denis is offline
Old January 14th, 2004, 11:25 PM   #17
<<<-- Originally posted by Paul St. Denis : Maury what codec are you using for export?
I believe my version of FCP defaults to DV-NTSC -->>>
I generally use DC30+ or Pixlet codecs.
After entering:
I select:
Settings: 'Current Settings' or 'Custom'
If 'Custom' then select 'QuickTime Video Settings': e.g.
Compressor: 'DC30+' or 'Apple Pixlet Video'
Quality: 100%
Click OK
Check 'Make Movie Self-Contained'
Click Save.
Good luck.
Maury
Maury McEvoy is offline
Old January 15th, 2004, 01:22 AM   #18
I gather that you can choose that setting (DC30+) as you have a Miro DC30+?
As I have gone to mine and can not find it in the menu.
Sharon Fraats is offline
Old January 15th, 2004, 01:35 AM   #19
MPS Digital Studios
Good luck and have a TON of hard drive space! I was shocked to learn a simple 14 second clip from the HD10 saved as a Pixlet QT movie was over 500 mb! YIKES!
heath-o
My Final Cut Pro X blog
Heath McKnight is offline
Old January 15th, 2004, 06:45 AM   #20
<<<-- Originally posted by Sharon Fraats : I gather that you can choose that setting (DC30+) as you have a Miro DC30+?
As I have gone to mine and can not find it in the menu. -->>>
Sorry for the confusion. I became aware of the DC30+ codec from posts by Eric Bilodeau both here and on:
http://www.lumieremedia.com/hdv/
You can download the DC30+ codec from the Italian site:
http://www.alfanet.it/squared5/dc30xact.html
I do not have a Miro DC30+ or any other associated hardware on my G5. The DC30+ codec works fine as a 'stand alone' codec.
Good luck.
Maury
Old January 15th, 2004, 09:15 AM   #21
Found it
Thank you
I'll try it right now and get back to you.
Old January 15th, 2004, 09:39 AM   #22
Given Heath's figure you can fit less than 5 minutes of Pixlet on a 4.7 DVD. Still good for archiving small projects.
Old January 16th, 2004, 04:15 AM   #23
RED Code Chef
There also seems to be a new DVD player that can decode
HD movies encoded in Windows Media 9 technology.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
