How many people own an HD10 or HD1 (and/or still use it) - Page 3 at DVinfo.net
Go Back   DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
All about the original single-CCD HDV camcorders from JVC.
Old January 25th, 2006, 12:33 PM   #31
Originally Posted by Dave Ferdinand
By the way Graham, does the HC1 have sharpening controls? And can you lock the AE as with the HD1? I know you can't lock both the aperture and shutter at the same time, like the JVC cameras, which really sucks.
If not with the HC1, can you with the AU1?
Patrick Jenkins is offline
Old January 25th, 2006, 12:46 PM   #32
Dave, yes the HC1 allows sharpening to be adjusted.
Regarding locking exposure .... I'm not entirely sure. There a lengthy thread on that somewhere here. My understanding is that I can lock the shutter (say at 1/60) plus the exposure (i.e. a combination of gain plus aperture plus maybe?? internal ND filters).
This is close, but not identical, to how the HD1 functioned - the difference being that with the HD1 when exposure was locked the shutter speed could sometimes change from what I wanted it to be. To complicate matters, the setting it would drift to seemed to differ on different cameras - at least if the forum discussion here was properly summarizing the situation.
One thing I learned just this week is that the HC1 "cinema" mode appears to be true Cineframe30. I have no interest in 24p, but I did like editing in JVCs 30p, so I am about to do some experimenting with generating 30p footage from the HC1. Who knows, maybe I'll even down-rez it to 720 ... and it will be just like old times with the JVC!
Graham Hickling is offline
Old January 25th, 2006, 02:23 PM   #33
Don't forget that the cinema mode would give you 1440x540 which is actually less vertical resolution than an SD PAL camera. At least theoretically.
Do or do not, there is no try.
Dave Ferdinand is offline
Old January 25th, 2006, 02:35 PM   #34
Oh poop! For some insane reason I had thought Cineframe 30 was doing something a bit more sophisticated than that. I just checked Adam Wilts article and sure enough:
"Cineframe 30 on the 60i FX1 ... throws away one field and doubles the other. The resulting image has half the motion resolution of the normal interlaced mode and appears like a progressive frame, but it only has a single field's worth of information, so its vertical resolution is somewhat degraded, and diagonal lines may look "steppy" or "jaggy".
Thanks for the head-up on that!
Old January 25th, 2006, 04:37 PM   #35
I still use my two-and-a-half year old HD10. I wonder what would be available today if JVC hadn't opened the flood gates!
Dave
David Kennett is offline
Old January 26th, 2006, 10:56 AM   #36
MPS Digital Studios
Dave F., it's really 1080i and NOT cut in half. Take a look at the image, it's wonderful. Both the Sonys and the HD100 have great images. When treated well, the HD10 has great images, too.
Any of the new HD10s/HD1s (made in 2004 and beyond) have the official HDV logo?
heath
My Final Cut Pro X blog
Heath McKnight is offline
Old January 26th, 2006, 11:17 AM   #37
Still Got It!
I have my new XL2, and my XL1s, but I will keep my HD10 also.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline
Old January 26th, 2006, 11:35 AM   #38
Here's a crazy thought....
... maybe I'll start converting my Sony's 1080i footage to 720p30 in post, and then use the HD1 as my playback deck to my HDTV, at least until the dust settles on blueray, hddvd, hdmi and the rest....?
Although...hmmm...I guess I'd have to forgo any surround sound audio while I was doing it that way.
(BTW, I just asked in another thread: is 720p60 a valid HDV transport file format, and if so what, if anything, can play it presently? Not the HD1, presumeably?)
Old January 26th, 2006, 11:45 AM   #39
MPS Digital Studios
I wonder if you can shoot in 1080i60, convert to 720p30 and have the JVC read and record it?
heath
Old January 26th, 2006, 12:10 PM   #40
heath
Sure! A JVC 720p30 transport stream is one of Cineform's HDV export options out of Premiere...
Old January 26th, 2006, 12:19 PM   #41
heath
Hey Heath, I was talking about Cineframe mode only, which is line-doubled. Therefore you get half vertical resolution. In standard 60i of course you do get full 1080 lines split in two fields. :)
Old January 26th, 2006, 11:55 PM   #42
MPS Digital Studios
I've read several items that said CineFrame mode only drops quality 25%, though I don't notice it so much in CF30 or CF25. CF24 seems to drop a bit.
heath
Old January 27th, 2006, 07:32 AM   #43
I've just posted a resolution chart comparision of the Sony HC1's 'normal' and 'cinema mode' footage in this thread:
http://www.dvinfo.net/conf/showthrea...096#post420096
Also, as explained in that same thread, the HC1's cinema mode in fact appears to me to be CF24, not CF30. Cineform's "3:2 pulldown removal" works nicely on it.
Old January 27th, 2006, 09:59 AM   #44
MPS Digital Studios
Graham,
post that in the HC1/A1 board, because we're off track here in HD10/1 land:
http://www.dvinfo.net/conf/forumdisplay.php?f=99
heath
  You are here: DV Info Net > And Now, For Something Completely Different... > The Archives > JVC GR-HD1U / JY-HD10U
